Question about Necchi 3102 Mechanical Sewing Machine
My bobbin case and holder came loose not sure how to put it back
1 Related Answer
SOURCE: i have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Posted on Nov 02, 2012
The bobbin thread gets stuck on the bobbin case holder what do I need to do the fix this issue
make sure the thread on the bobbin rolls away from you when you put it in the bobbin holder. insure that the bobbin and bobbin casing are installed correctly.
mike (really by my wife Sandy)
May 28, 2018 | Sewing Machines
C an not get the bobbin cover to go back on
try a different bobbin, make sure the bobbin is seated correctly in bobbin case,,take a can of air & use it on the bobbin case area,,also check for lint or loose thread in bobbin case area
Feb 09, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
First the top tension started being loose, so I changed the tension different ways and tried to fix it...now the thread is getting all tangled up under the fabric and is locking up. Also giving me the E6...
Do you mean the stitching on the top of the work was loose? If so, you should check the bobbin tension. Make sure you have the thread pulled under the tension plate or spring on the bobbin case. Tension should be just enough that you can suspend the bobbin in the case by the thread (think yo-yo). Upper tension should be tighter than lower. Make sure you put the presser foot down.
Sep 01, 2011 | Brother CS6000i Computerized Sewing...
Hi, using a jonome finesse model 356, changed the thread on the bobbin and now its knotting up and not loose from the bottom, did i thread it incorrectly? tension is wrong now?? thanks!
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Apr 11, 2011 | Janome Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
The casing that the bobbin sits in is out how do I put it back in. The Bobbin holder below the tension feet is out and so is the bobbin how do I set it back in with out undoing the two latches on the side...
put the bobbin in its case then pull some thread out and pass it thru the bobbin case slot and under the tension spring .. put the bobbin and case over the shaft that is in the main unit .. the open side of the case goes in first .. make sure the bobbin doesnt fall out .. rotate the bobbin case until its finger lines up with the notch in the main case .. the bobbin case should latch in place on the shaft notch .. place the top thread under and to the back of the pressure foot then turn the machine one turn .. that will loop the top thread around the bottom (bobbin) thread ... now use a card or screwdriver to push both threads from under the pressure foot toward the back of the machine ..
Jun 21, 2010 | Singer 8280 Mechanical Sewing Machine
I HAVE A HUSQVARNA 415 SEWING MACHINE. I AM LOOKING FOR THE NAME OF THE PART THAT YOU PUT THE BOBBIN INTO. I ORDERED A BOBBIN HOLDER, BUT THAT IS NOT IT.
The bobbin fits into a bobbin case (holder), the bobbin case is what you take out to put a new bobbin in. The bobbin case fits into the hook (it has a spindle in the center) which you do not take out of the machine unless you are doing maintenance. If you just ordered a bobbin holder, it could be for another machine. you must get a case made for the machine, a generic one will not work.
May 22, 2010 | Husqvarna Viking 1
I have a Singer Merritt 4530 and the black bobbin holder thingy came out. How do I get it back in without bending it. Do I need to remove the plate with a screwdriver?
make sure the small silver clip is pushed to the left, pop the bobbin case and. make sure the needle is all the way up first, put the clip over the bobbin case.
Sep 10, 2009 | Singer Sewing Machines
Can't put the plastic bobbin holder back into position
make sure the needle is all the way up and the bobbin is in the case the right way. check to be sure there is no lint or dirt impeding the case. you may have to take out the piece the case fits into to do this. i have found this to be the problem more times than not.
May 11, 2009 | Yamata FY700 Mechanical Sewing Machine
Necchi 3102 Mechanical Sewing Machine Logo
35 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
