Question about Dell PowerEdge T410 Server
No Display Display wont turn on. I have checked all connections and RAMs but no luck.
Robert Lissor
    Sergeant:
  • 263 Answers
You need to check the Video card , If you have one bult into the MB you may have to remove it and install another card. To disable the onboard card go into the BIOS
Posted on Nov 26, 2014
  • Cory Kielion
    Cory Kielion Jun 14, 2015
    How - exactly - does one remove a video card that is built into the MB? Hmm? ;)
My machine is konica minolta c252 my touch screen dont show any thing and havent light its hust black screen and i changed cable also not fixed pleas any one can help what is way for solve
Black Screen
When you turn the machine ON, if there is no display on the control screen and also there is no sound of warming up, then the problem is with the Print Conrol Board, (Main Mother Board) replace it and your problem is solved.Before doing that you can try replacing the RAMs.
Secondly, If you hear machine's normal warming up rotation sound and there is no display on the screen then please check the Display Cable, white VGA like cable connected with the control panel.Check, it may be loose or not properly connected.
Jan 24, 2015 | Konica Minolta bizhub Office Equipment &...
Compactor wont shut off. is all the way up
Check the upper limit switch, you may only have an issue with the contact arm to sense the rams position. Look there first before buying anything. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 20, 2014 | KitchenAid P Series Trash Compactor -...
6 beeps are coming and no display in ds20e
well first thing would be to diagnose the problem. motherboard beeping indicates some hardware fault.
check all connections, also, do you know by any chance what motherboard you got inside? googling for error codes for that particular motherboard might surface what those beeps indicate and help steer you in the right direction.
If not, you'll have to take the thing apart and do some of your own testing.
Mar 04, 2014 | Compaq AlphaServer DS20E
When i turn my monitor on the lights will come out but after a second it say"power saving mode" What should i do..how many times i try i unplugged all then try again but still the same. please...
Your monitor is not taking display from your PC. Check display cable or unassemble the RAMs of your computer and it is better to blower the computer and after it reassemble RAMs and start again. It will helpful. If the problem does not solve kindly contact me again.
Aug 11, 2011 | Computers & Internet
When I power up everything seems to work but there's no display in the monitor and nothing on the POST-CODE LED, and no beeps. I tried to find the problem by unmounting all the pieces installed on the...
hi,
if you dont have any beeps
the mother board usually damaged , but for assurance , do the follow:
1- chek the power and see all of the cables inserted correctly and spcially check the voltages
of 12 v and 5 v by connecting the volt meter :black cable of one of socket of power to ground
cable of volt meter and one time connect the other cable of volt meter to red cable of power
socket which should be 5 v and other time connect to yello cable of socket power which should
be shown 12v .
if ok ,
2- chek the ram or rams may be inserted incorrectly.
3- check the graphic card may be inserted incorrectly.
4- check the capacitors around the CPU may be swollen.
if you did noy any problems , you must refer to a technician or gaurantee .
good luck
gorbesia
Jun 19, 2011 | Intel DP55KG Motherboard
When i turn on the computer i can hear the computer opening but the monitor does not open, sometimes it flickers then black. I have to play with the power button several times to get the screen to come up....
just check out by your rams. because tyhe problem may be with the rams .if the rams are working fine just connect the monitior to the opower socket.do not connect the monitor to the cpu .if the monitor switches on perfectly thenthe problem is with the motherboard .
Oct 03, 2010 | Computers & Internet
Acer aspire x1700 64 bit system powers up, but no display on monitor. I've connected monitor to mb display with no success. I installed a new DVI display adaptor, with no luck. I am apparently not...
Check your ram. put out all ram from pc and start your computer. than put one ram in pc and start the pc if it is work than the problem is in one of you rams.
May 03, 2010 | Acer Computers & Internet
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Computer beeps on sart up no display
Try another display or display cable.
Jul 07, 2008 | Computers & Internet
Dell PowerEdge T410 Server Logo
147 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
