SOURCE: hdmi port
I have a 50 inch and recently had to have the main board replaced d/t the IR receiver was failing intermittently. Since they replaced the main board, one of the two HDMI is doing the same thing (picture, no sound). When I spoke to service they felt the issue was related to the replacement board and will be replacing. The weird thing is the picture is not quite right + no sound. Usually with HDMI it's either all OK or not OK at all. In any event, my problem seems to be the main board.
SOURCE: HDMI, picture but no sound
Check the menus for both the DVD and TV to be sure that the audio is being sent thru the HDMI cable. Some sets and DVDs will separate the audio from the video be default unless told to send it down the HDMI. Update this if that does not resolve the problem and post the make and model of all gear in the chain.
Thanks,
Dan
SOURCE: HDMi cable hooked up, but I get an
you have to go to the input button on the remote and push HDMI
SOURCE: when we plug the blu
Hello
Unfortunately your TV is only HD ready. This means that it plays video in 720p. A full bluray disc is 1080p. Im afraid your tv will most likely not be able to handle a bluray player.
:( sorry
Hope this helps
SOURCE: TV: LG 42LE59000. BLU
You might need to replace the SSB signal Board.
Look on website shopjimmy,com for replacement board.
