Will class 66 bobbin work
SOURCE: I have a Huskystar C20 sewing machine and the
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
SOURCE: I have lost the manual
contact huskqvarna website & you can find a dealer that should have one or try these sites
sew usa
sewing manuals.com
ebay
SOURCE: How do you adjust the bobbin tension in the
There is a screw on the bobbin holder. Clockwise=tighten, counter-clockwise=loosen. Hope this helps!
SOURCE: i have a huskystar 219. The feed teeth will not
You will need to clean the feed teeth and hook assembly area. Turn off and unplug your machine and then remove the presser foot, needle and needle plate. Use the lint brush that came with the machine to scrub out the feed teeth and hook assembly area.
