Just replaced all outer handles and 2 interior handles and a door latch on a sport track. The biggest problem with the locks were that they needed to be lubed. Take a spray like wd-40 and spray the latches. If the door panels are still off then it is easier. Also spray the window sliders to have them work easier. All the actuators work off the same signal. The one that does not work just may need a little lube.
Hello there patsey! I've seen this many times before. It sounds like a window track problem. The window glass rides up and down inside the trackwork channels. Those channels sometimes bend or break and cause the window to run crooked. You wont really know for sure what the exact problem is until the inner door panel is removed so you can inspect it. Best case scenario is the track bolts have come loose and just need tightening ($50-$60 repair). Worse case scenario is that the entire window track or window regulator assembly needs replacing. This can sometimes run upwards of $200 or more. BTW, removal of the door panel just to inspect it should run no more than around $30- $40. Hope this helps.
Real musicians do change tempo throughout a song, so its not necessarily a bad thing. As long as you like the sound it doesn't matter if you don't stick rigidly to a fixed tempo. Unfortunately you won't be able to fix the tempo after the initial recording so you'll have to live with it or re-record. If you need a click track to record along to, try recording yourself hitting drum stick together along to the already recorded track. As a human you can track small tempo changes much easier than a computer. If you need to create a count in, just copy and paste a section of this click track to the start of the track. I hope this makes sense!
I'm the same... I've been looking at everyone else doing it online and they crash aand do it really slow and still pass... but I've been doing it heaps and I just can't get past it. Got the same version as you. Wii with that cover.
As far as I'm aware there is no way to record to just one of the stereo paired tracks (channels) on the 2488. There are individual mono tracks underneath those channels, but they are controlled with one fader and can only be recorded to in stereo. They are designed to be used for recording stereo sources and stereo bounces. You can however record to any of tracks 1 to 12 and then move (assign) that track to say track (channel) 13 or you can clone any single track to any other track (channel).
The term track can be misleading on the 2488. It might be easier to refer to the 1-24 fader controlled 'tracks' on the 2488 as 'channel strips' and refer to each of the 250 virtual 'tracks' on the 2488 as 'tracks'. You can assign any of the 250 virtual tracks on the 2488 to any of the channel strips. So you have 250 tracks available, but can only work with 24 of them at a time. The stereo pairs just offer some extra convenience when working in stereo. They allow you to control the volume of two tracks with one fader making working with stereo easier.
Channels 1 and 2, 3 and 4, 4 and 6, ...11 and 12 can also be linked as stereo pairs and will be controlled with the fader of the odd numbered (first) track when linked.
Your radio will require one of the following procedures.
Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears). Then using your remote enter your code.
Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3 Model# DPX-4020 and DPX-4030 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key * Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
