Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
What is resistor 7's value on the USB to IDE board
Posted by SKSXS on
Ken Murray
  • 77 Answers
Read the color codes on it. They will tell you it's value.
Posted on Jan 19, 2008
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
Value of R065 on power supply module of the RX-884V
value not cost $ but a resistor is it to hard to say resistor.?
OHMS and color bands all that is easy but no VALUE eve guessed
and if burned up and my guess it did (not said)
and guess what even if you had a correct resistor
it too will burn up, due to other part is shorted 99% chance.
see?
HP does not publish schematics.
what we do is buy a new one. every time.
Feb 21, 2016 | Compaq rx884-69001 - 2.4x Ide Hd Dvd-rom...
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
Nov 18, 2013 | Vizio L32 32 in. LCD HDTV
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Computers & Internet Logo
35 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
GFXTech
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
