Wega Mininova EPU Espresso Machine Logo
A
Anonymous Posted on Apr 04, 2014
Bunn tank too full and won't drain - Wega Mininova EPU Espresso Machine
My bunn coffeemaker NHS-B trip the GFI. Where do I find the code date on my brewer?
The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
Bunn VPR 12-cup pourover is leaking water from the back at the bottom every time I pour water in. It leaks about 1/2 cup or more. Is there a seal or gasket I can replace to remedy this?
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
2answers
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
5helpful
2answers
BUNN VPR commercial coffee pot, not flowing in a steady stream just dripping
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
1helpful
I want to know how to drain the water and get the lime out of the tank
Unplug, cool down, remove carafe and basket, turn unit horizontally over sink. It will drain faster if you remove the screw on "distributor" (nozzle). OR do not drain. Just add the plastic pitcher full of a 50% white vinegar solution, let heat then turn off for 1 hour. Drain OR add 4-5 pitchers of cold water to rinse.
Top Wega Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
