Samsung Digimax D53 Digital Camera Logo
A
Anonymous Posted on Apr 04, 2014
How do I delete pictures from camera? - Samsung Digimax D53 Digital Camera
Timb
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Apr 01, 2015
Timb
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
1033
Points
19
Try the button that has a trash can on it.
Can you delete pictures on a Sony G camera all at once?
Follow these steps to delete all pictures from the memory card in your Sony Cybershot camera
Delete All Pictures from Sony Cybershot Step 1 Turn on camera and make sure it is charged.
Step 2 Press the Playback button (confirm that you want to remove all pictures from the memory card)
Please note - at this point, if you hit the delete button the camera will delete one picture at a time. Before I figured out how to delete all pics this was the point where I got upset, thinking that I had to delete 600 pictures...one at a time.
1helpful
How can i delete videos and pictures?
To delete pictures in your camera at once, you can delete it using the computer. Plug your camera to your computer using the USB cable. Once your camera being detected go to My Computer, double click the drive of your camera, " I think it is drive E or drive F". Now your are opened the drive you can see all your pictures. To delete all the pictures, click one picture. Press control A at once int the keyboard, so all pictures are highlighted, press delete and Yes. All the pictures are deleted..
thanks.
Apr 07, 2011 • Cameras
4helpful
How to delete pictures from my camera as i can't find my manual and i have not used it very often
If you want to delete selected pictures, follow below procedure:
Press Play button that is located under navigation buttons, see the picture in lcd that need to be deleted, press Delete button located it lower right corner, camera will ask confirmation, press OK by center button in navigation buttons to delete selected picture.
If you want to delete all pictures at once, go to Menu and select Format option to delete all pictures/ video clips etc in memory card.
Click Sony Support to download DSC-S730 camera user manual and check page-15 for details.
Thanks.
4helpful
3answers
Can't delete old pictures
It depends on the brand or model of camera you are using, but if you cant get how to delete a picture from your camera, simply get a card reader, then remove the memory card of the camera and insert it into the card reader, connect the card reader with your computer, so from your computer you will be able to delete old picture. But I still know that most digital cameras should be able to delete old pictures, simply read your camera manual to see how to delete or you tell me the model and brand of the camera that you are using.
Sep 22, 2009 • Cameras
3helpful
3answers
How to delete all the pictures on my camera.
re format you memory card in camera it should be in menu then settings then memory try it
4helpful
Delete one picture at a time
Put the camera in picture review mode. Click through the pictures until you find the one you wish to delete. Then press the trashcan button on the back of your camera to delete just that picture. Select OK if asked to erase this picture.
2helpful
How do I delete my pictures
There are 2 ways to delete pictures.
set your camera in playback / view mode and press delete button near menu button at rear of camera. pop up comes to ask delete...select yes and there it goes.
connect your camera to computer usb port and go to picture folder through My Computer > Removable Disk, select desired picture file to delete and press delete key at keyboard.
Need more info, please ask.
4helpful
2answers
Deleting pictures from cybershot viewer
This is not working!how can i delete pictures form my cyber shot viewer?
11helpful
5answers
Deleting pictures from camera....
press menu
go to setup
scroll down to the second option: memory stick tool
go to format
re-set the format to "ok" even if it says "ok" already
press ok to all dad in memory stick will be erased, ready?
and all the pics will be deleted. thats the problem with this camera, everything is good except trying to figure out how to delete them all!!! ughh
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
