Question about Sanyo DVW-5000 DVD Player/VCR
How to hook up cable to Sanyo TV DS19380? - Sanyo DVW-5000 DVD Player/VCR
3 Related Answers
Anonymous
  • 173 Answers
SOURCE: Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Posted on Sep 06, 2007
vic richards
  • 75 Answers
SOURCE: I was watching my tv (sanyo) with cable hooked to
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Posted on Mar 06, 2009
Anonymous
  • 12 Answers
SOURCE: Need Universal Remote Code
try this webaddress http://www.xdiv.com/remotes/
Posted on May 10, 2009
What do I need to do to hook up cable to this tv?
This TV has the following inputs:
RF input, composite video/audio input
The easiest would be to use coax cable
I have a 2002 Sanyo tv what do i need to make it work with out the cable company
do you mean you want to use the tv not through cable program?. ok just remove the cable box then hooked up an air antenna to the RF tuner. then change the settings in the tv select air not cable.
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Need remote codes -- have cable hookup
I found that this website should have all the codes and instructions for most remotes
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
1helpful
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
Hook up instructions
has this problem been solved yet? hookup is easy
6answers
Need tv code for remote control
¿Porque siempre preguntan por el codigo para el control pero nunca ponen el nombre del control y el modelo ?
Cable ready tv components
This part is called a coaxal RF connector.
Sanyo DVW-5000 DVD Player/VCR Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
