Question about Nikon Coolpix 4600 Digital Camera
System error 10 - Nikon Coolpix 4600 Digital Camera
Cod 10 error
Windows Code 10 Error is caused by misconfigured
system files.
If you got Code 10 Error then there is a 96%
chance that your computer has registry problems.
This error should be fixed
immediately to prevent further damage to the Windows system.
Oct 12, 2013 | Matsonic MS9127C Motherboard
System error in designjet 500 plotter error code 20:10
The error code 20:10 does not appear to be a valid error code. The plotter may be misinterpreting the code. Try disconnecting the service station (power off). It is the bundle of green wires plugged into the small interconnect board behind the display. You will need to remove the right end cover to see it. That should generate a 21:10 error when you power up. You will need to hold down the top cover interlock. If you get the 21:10, reconnect the service station cables and disconnect the cables going to the ink supply station. When you power up you should get a 22:10 error. If either of these causes the 20:10 error, that module has a problem.
Oct 03, 2013 | Office Equipment & Supplies
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Dvd error code 10
Cause of the Code 10 Error A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
The safest thing to do is to perform system restore or
run SYSTEM RECOVERY.
If you will use sysem recovery it fix all the problem of your computer however all files on your hardrive and softwares that you installed will gone.
It will be back from original manufacturer settings just like the same thing you got your computer.
Dec 30, 2011 | Sony VAIO S360 Notebook
Error : 10-FC12-0002 comes up during Toshiba system rocovery what does it mean and how do i fix it?
I download this from the Toshiba support site:
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D / 10-FC11-045D" -- may be caused by a faulty hard drive. *****
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
*for this error 10-FC12-045D u nid to call 1-800-457-7777 toshiba advance technical support they will send it to depot or they will recommend ASP (Authorized Service Partner)
I suppose your recovery disks could be bad. You can get another set from Toshiba. I'm also concerned about the health of the hard drive. Did you need to run recovery because the system crashed, because it may not have been an operating sysem crash but rather a hard drive crash. Have the harddrive or whole laptop checked by a reoutable repair person or check my website: www.micromendllc.com
Mar 03, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Error code 10-FC06-000D while using recovery cd (backup)
Error code 10 XXXXXXX is related to hardware. It is default code generated by device manager when the operating system failed to determine which specific error code to return after an error occurs.
Error code 10 error pertains mainly to hardware issues and to compatibility issues between hardware and the software.
To troubleshoot the code 10, go to control panel>system> device manager and check if any of the hardware display a yellow “!” or a red “stop”.
1). Update the hardware device driver from either Microsoft or device vendor web site.
If the device is preinstalled on the computer, visit the computer manufacturer’s website.
2). Make sure the device is enabled in the computer BIOS. You need the system documentation, if you don’t know how to do it.
3). Disable any advanced feature of the device.
4). Install the most up to date service pack and any other updates.
Oct 29, 2008 | Toshiba Satellite A205-S4617 Notebook
WINDOWS MEDIA PLAYER 10 WILL LOAD BUT WILL NOT RESPOND WHEN I WANT TO GO TO LIBARY OF STORED MUSIC. TRYED UPDATES, RELOADING, REINSTALLING , NOTHING WORKS , NO ERROR MESSAGES EITHER, PLEASE HELP...
Reboot system in safe mode. It will ask to restore to previous restore point. Try to select restore point before you have installed windows media player 10. Reboot the pc and then try to install media player 10. It will be better if you run scandisk to fix file system errors. Or you can use any tools for fixing file system & windows system registery error like System Mechanic, Symantec Windoctor.
Thanks,
Vksr.
Oct 13, 2007 | Computers & Internet
Nikon Coolpix 4600 Digital Camera Logo
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
