If they are alrady on te same router / WiFi, make a drive or folder 'shared' and then on the other use 'Map network drive'
If not, then just use any old Ethernet cable to link them (both PC's should be happy enough to set a default IP addresses and 'see' each other) - modern PC's don't need special 'switch over' cables (a 5m Ethernet cable from the £1 shop will work fine)
On the PC you want to 'expose' data, you 'Share' the folder (right click for the folder 'properties', look for 'security/sharing' etc).
On the other you 'map network drive' (if asked for a user name/log-in, use the account on the OTHER PC ..)
