There are a few things you can try to fix your Vax rapid power plus upholstery hose:
- Check the water tank: Make sure the water tank is full and securely in place. If it is not securely in place, it can cause a reduction in water flow.
- Check the nozzle: Remove the nozzle and clean it thoroughly. If there is any debris or buildup, it can cause a blockage in the nozzle and reduce the water flow.
- Check the hose: Check the hose for any kinks, twists or damage. If there are any kinks or twists, it can reduce the water flow. If the hose is damaged, it may need to be replaced.
- Check the pump: Check the pump for any blockages or damage. If the pump is not working properly, it can reduce the water flow.
If none of these steps work, it may be best to contact Vax customer support for further assistance or to have the machine repaired.
