Question about HP Scanjet 4470c Flatbed Scanner
Color lines After reinstalling our hp scanjet 4470c, all scans now have a repeating pattern of three horizontal lines of color (yellow, red, and green) on all scans. Any suggestions?
Posted by trork on
Thomas Christopher
    Genius:
  • 1,601 Answers
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
Anyone found driver for WINDOWW 7 & HP scanjet 4470c yet?
The only ways to get scanner 4470c run under W7 are these 3 options :
1° solution one : make sure driver XP ( yes XP ) is correctly installed . Download and install FreeKapture from http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html . Load FreeKapture , clic on Scan and select WIA-Hewlertt-Packard . Scanner will work fine in this mode but if you choose PrecisionScan Pro , program will hang .
In any case , no slides or negative scans possible but the rest works .
2° solution two : if you have XP install disc , you can install a virtual version of XP on your HDD ( http://www.vmware.com/products/player/ )
3° solution three : if you still have XP install disc , partition your HDD and install XP on the new one (http://www.partitionwizard.com/free-partition-manager.html ).
Don't wait for HP to produce compatible drivers for this unit , it's useless . Regards .
Fanaudi .
Feb 26, 2010 | HP Scanjet 4470c Flatbed Scanner
THe scanner works but the image is blank/no image
Try automatic settings or vary the brightness/contrast setting and scan. This should work. S. Mohan
Jun 13, 2009 | HP Scanjet 4470c Flatbed Scanner
A yellow line appears on all of my scans. How can solve this?
Check the glass of the scanner. It may have some stain over it.
Dec 13, 2008 | HP Scanjet 4470c Flatbed Scanner
Scanning 35 mm slides
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 4470c Flatbed Scanner Logo
815 people viewed this question
Ekse
Thomas F. Schneider
