Harassing calls
Here is the user manual:
Samsung SCH U365 User Manual Ver fb03 f6 English north America
Yes. Theres an app called block it. You can use google to get the app.
SOURCE: Block incoming unwanted calls
no your mobile does not support call black listing features. there are some softwares available. i think your phone is not built with symbian operating system. Check whether your mobile supports symbian os. there are more call blacklisting softwares for Symbian os built mobile phones. Else if your mobile is java compatible then try to find some call blacklisting java softwares from websites
SOURCE: Block incoming calls
go to setttings then call barring then incoming calls then activate, this should block all incomming calls.
the better way is to download this program and block only this number that's bothering you. here's the link for the program:
http://en.handybyte.com/cat/system-utilities/communications/blackballer-(super-blacklister)/
SOURCE: Incoming call blocking
the call must be blocked from the tower in order for your phone not to react to a connection attempt from that particular mobile device number. you can contact your service provider and they may have a work-around or a fix for you.
the easy way though, and the way i recommend as long as you are wanting to block calls and not txt from this number, is to asign a custom ringer as none. this will silence your device and deactivate the vibrate mechanism.
now when that # dials yours, you are not disturbed.
or if ur realy serious just call ur service provider and they can fix u up.
pls rate this fix
SOURCE: I want to block unwanted calls
its have black list software for your probleam
if u use that software u can control them unknown numbers as u wish
