When filling my bobbin, it filled and then I could not remove it from the machine.
Some how the bobbin got wound too tight. The thread must have been caught along it's path or something. You will have to unwind the thread off the stuck bobbin. Once enough thread is off the bobbin it should pull off. After that, throw that bobbin in the trash, it is now deformed and most likely will not work anymore. If you wind your bobbins with the machine threaded always make sure you have your presser foot up and Always use a metal foot.
SOURCE: Bobbin stuck on winder
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
SOURCE: Have a husquvarna viking 200 machine and the
I'm assuming you are talking about the rewinding mechanism on top. There are grooves in the bobbin which fit on to the rewinding spindle that holds the two together while the bobbin fills. It may be they have gotten out of synch or the bobbin is a non-standard Husqvarna Viking bobbin for that machine. These usually use green bobbins but they have come out with new colors but all have the Husqvarna logo on the bobbin -- an H. I would try to wiggle it slightly to try to remove it. If still will not come off, try popping it off with a flat head screw driver but be sure to put a folded towel under the screwdriver so that you don't damage the molding of the machine. If you still are unable to get it off, recommend taking it to an authorized Husqvarna Viking dealer. A list of dealers near you is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
SOURCE: freesia 415 - bobbin thread is jamming up will
1. Put in a new needle
2. Take the thread off the top of your machine and rethread the top. Make sure the presser foot is in the up positon when you thread your machine because that is when the tensions discs separate so your thread gets deep into the unit where it belongs. The tension dial (the small dial) should be on 4 or 5.
3. Inspect the bobbin area. Do you see the thread laying across the bobbin itself? You should alway see the thread laying across the bobbin in that model. That tells you that you've threaded the bobbin case correctly. The thread must be pulled into the metal guide of the bobbin case, from approximately the 6 O'clock postion to the 7 O'clock position.
4Never turn the handwheel away from you with the 415. You'll notice that the take up lever is of a more open design. If you turn the handwheel backwards (away from you) the thread will jump out of the lever and jamming will result.
SOURCE: I HAVE A HUSQVARNA 415 SEWING MACHINE. I AM
The bobbin fits into a bobbin case (holder), the bobbin case is what you take out to put a new bobbin in. The bobbin case fits into the hook (it has a spindle in the center) which you do not take out of the machine unless you are doing maintenance. If you just ordered a bobbin holder, it could be for another machine. you must get a case made for the machine, a generic one will not work.
