Question about Lexicon Music
Cant find activation code
Cubase is asking for an activation code but i cant find it
Posted by chris wallace on
Hi! I just recived a Lexicon Alpha desk top and i cannot find the actavation code. Therefore i cannot activate the recorder "i guess" or can i?
There is no activation code. You will need software that handles I/O sound device other than the built in audio of the PC. This device is sometimes delivered with either Sonar home edition or CuBase.
Jun 13, 2011 | Lexicon Alpha Personal Recording Studio
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
I have a behringer Xenyx 1622 mixer and am using cubase when i plug it in the it says its ready to go but, something happens and theres no volume..and i cant set it up in cubase?...any suggestions..
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Apr 27, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
CAN'T GET ALPHA TO WORK IN CUBASE OR AUDACITY ?
See if this info here will help you:http://www.lexiconpro.com/knowledgebase.php?product=7 Let me know if this helps.
Nov 30, 2009 | Lexicon Alphaâ„¢ Desktop Recording Studio
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Jan 06, 2009 | Zoom H4 Handy Recorder
Music Logo
32 people viewed this question
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
