Invacare Pronto M51 Power Wheelchair Logo
James Milligan Posted on Apr 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Com fault codes
Light blinks9 times then repeats chair will not move
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Apr 08, 2014
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129811
Points
552
This flash error code of 9 indicates a communication fault. With this model the problem is usually the connecting cable between the joystick and the computer module in the base. Check the connectors and wiring and cover on this cable for loose,broken , or disconnected terminals and wires. I usually replace the cable with a known good one to test. The second component that may have failed is the joystick assembly. A local dealer may be able to lend you these parts to test or you can purchase them on-line. There are several different models and joysticks that are similar looking but have subtle differences. If you post your joystick model I can be more specific.
Hope this helps.
Joystick error code 7 flashing lights, 3green 3orange 1red
Check and see if the charger is still plugged in when you have this fault. Usually a 7 light flash is a controller fault. Sometimes it will also mean you have one or both motors disengaged. If the charger is not plugged in when you have this fault then try and push the chair. If it moves freely then you need to engage the motors. If you have to engage the motors you will have to power down the chair and power it back up to clear the fault. If this does not work you will need to contact a technician to troubleshoot the root cause.
My vision sport power chair won't move. the
says here thats a right motor fault, check the right motor connections and cableing
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
5helpful
2answers
All lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
These will tell you what the fault is; repost with more information.
4helpful
2answers
The lights are flashing and i cant get the chair to move. What should I do?
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
10helpful
The battery is charged but the lights just flash and chair doesn't move
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
1helpful
Go to turn the power on the controller of a Jazzy 1143. The lights on the controller flash and no power goees to the chair. Have checked all connections and still nothing works.
Flashing lights indicates a fault. Here' the users manual which contains the fault codes for the flashing lights. Repost with more info re: the fault codes. Good Luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jazzy_1143_om.pdf
Also, make sure the charger is not plugged into the chair.
2helpful
2answers
Won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
3helpful
2answers
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
