The machine just hums when it should be filling for the rinse cycle
SOURCE: Washer fills, but doesn't do anything else
if it fills then the power is there open the lid and make sure all connectors are on to the timer if they are then more then likely u have a motor problem check carbon brushes if these are low then the motor wont turn the drum if there is no carbon brushes ull have a module if this is faulty most of the time its cheaper to replace the washer m8
SOURCE: Will not go through the rinse cycle not filling
your cold water is turned off
if you check its not than where the hose connects to washer for cold water disconnect it and make sure its clean in the hose and the part of the washer it connects to
there might be rust
if it is clean than you need a new water valve
reply if u got questions
SOURCE: Danby front loader becomes very loud during spin cycle
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer.
SOURCE: Danby front load washer Will not spin motor runs
I just had the same thing happen.
Clean the lint trap at the bottom left. Use a coin to unscrew the cap, then unscrew the filter that is is front of the pump. If the water is not ejected, then the machine will not spin faster.
SOURCE: Danby DT4229 Top Load washer. the washing mecahism
HI. If the timer dial dose not advance, this will indicate that the timer motor has failed. Generally, this will require you to have this damaged timer mechanism replaced, asap. Unfortunately, these mechanisms are not designed to be repaired. The entire device must be replaced, if possible.
