Question about Bunn BX HOME BREWER 10-Cup Coffee Maker
Thermal Fuse for Bunn GR-10 - Bunn BX HOME BREWER 10-Cup Coffee Maker
Mark Cheong
    Master:
  • Bunn Master
  • 791 Answers
Check bunn.com for free download of manual.
*** the following is for information only. Equipment should be service by a qualified tech. ***
* Thermal fuse is pretty standard for all bunn equipment. They are readily available from many on line sources as well as a local restaurant equipment store (FESCO, Restaurant supply parts, etc.)
* though thermal high limit fuses blow when no water is in the brewer when powered up. This means the heater element got hot enough to melt things and eventually over heat the fuse. Replacing the fuse may not solve all your brewers problems.
* It might be wise to check for a repair kit on line, just to be sure your covered for other problems.
* Final, Check your warranty before performing any repairs. You could probably get the whole unit replaced.
Aloha, ukeboy57
Posted on Feb 08, 2018
1 Related Answer
atbsmmom
  • 189 Answers
SOURCE: GR-10 Bunn coffeemaker: Heating element is split
I do apologize but the part you are looking for is not available. Please look at the bottom of the brewer for the model and date code. Then contact customer service so that you can be assisted further. The machine carries a 3 year warranty so if it is 3 years old or less it will be replaced at no cost. If it is older than 3 years, it will be replaced at a reduced price.
Posted on May 19, 2010
My brand new gr speed brew by Bunn is taking nearly 15 minutes to brew a 10 cup pot instead of the 3-4 minutes claimed. Any advice to help?
Hello, Trent -
I checked the User Manual for the Bunn Speed Brew
< http://www.bunn.com/sites/default/files/care-and-cleaning/49740.0001.pdf >
and didn't find the problem you describe in the troubleshooting (Let's Solve) section.
Therefore, I recommend you telephone Bunn Customer Service and talk with a someone there. See this web page to find the right number to call and the days and hours of availability:
http://www.bunn.com/contact-us
The company may need to send you a replacement machine.
Dec 24, 2017 | Bunn Coffee Makers & Espresso Machines
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Dec 30, 2016 | Bunn Coffee Makers & Espresso Machines
I changed my thermal fuse on my Bunn grx-b because it was not heating the water. Now it's like it is overheating. What could it be
hope this is of some help
the thermal fuse is blowing because the unit is getting to hot you replacing the thermal fuse has not cured the problem, and it will blow again , the problem is the thermostat is set to high or is faulty / allowing the unit to go over temperature hence the thermal fuse blowing
its the control stat that you should be looking at. good luck
Nov 19, 2016 | Bunn Coffee Makers & Espresso Machines
Bunn Home coffee pot
If you remove the top , then remove the water basin, you will see the heater. At each end of the heater (inside a white tube) is a thermal fuse. Will read like any other fuse with a meter. They carry them at radio shack as well as other places. The temperature is on the side of the fuse. Needs to be replaced with the temperature.
Jun 18, 2015 | Bunn 10 Cup Home Coffee Brewer
How to fix a Bunn NHBX that produces warm, not hot, coffee?
Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
Mar 02, 2015 | Bunn NHBX-B Contemporary 10-Cup Home...
How do I fix my coffee maker
most of tank heater of BUNN have some thermal fuse connected along thhe line before the heater terminal .that fuse might be open or worse ur heater spoiled already
Aug 31, 2014 | Bunn 10 Cup Home Coffee Brewer
Wont heat water
Probably the thermal fuse to the heat element. Use a test meter to run a continuity test through the fuse. You should be able to get a replacement fuse through your local dealer or electronics store such as Farnell, RS Components, Radio Shack etc
Apr 20, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn coffee maker, no hot water
Mar 16, 2013 | Bunn CWTF35
Bunn BX HOME BREWER 10-Cup Coffee Maker Logo
138 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
