Question about Champion 3500/4000 Watt Portable Generator
My champion qenerator 46596 will run but no electric comes out
Posted by Eric Collier on
My Champion dual fuel 9000 watt generator had low oil and it shut off. Upon replacing the oil, it runs for 3 seconds and shuts off.
Make sure it's right on the dot any over fill it won't run .use non detergent oil only so it don't bubble
Aug 08, 2018 | Electrical Supplies
What should be the voltage at the brushes of a running champion 9k watt generator.
might find something here
https://www.google.com/search?q=champion+generator+troubleshooting&rlz=1C1GGRV_enUS751US753&oq=champion+generator+troubleshooting&aqs=chrome..69i57j0l3.10135j1j8&sourceid=chrome&ie=UTF-8
May 24, 2018 | Cars & Trucks
I have a 2001 Dodge Stratus and awhile ago I switched the plugs to a Autolite plug. Then I decided there might a problem and went back to the Champion plugs.
I believe the factory originals are champion brand, and would have been platinum, but it should still run decent with the coppers. The only thing I can think of is they are of the wrong gap. Copper plugs do not come pre- gapped at all and need to be done by installer. The gap for your stratus, if it's a 4 cylinder is .050. Wrong gap will cause no power and shaking. Correct champion number in copper is #443, and should say that on the box/plug.
Jan 15, 2017 | 2001 Dodge Stratus
I have an old champion electric lawn mower that is VERY noisy can I oil it & where?
It's probably a bad bearing, you can try to remove it, then look on the bearing race for numbers and letters, and try to track that particular bearing down on the Internet. It may be too much work or money to fix though, most things are pretty much disposable these days.
Aug 07, 2016 | Electric Garden
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
My champion generator model #46596 will run but won't give electric
All breakers OK? Then it could be lost exciter current. Her's how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With the generator running, insert bare wire ends into the AC outlet - one wire to Hot, the other to Neutral. Insert and remove quickly - there should be a flash and power will be restored. If not, repeat until you get that flash. If you are too slow to remove the wires from the outlet after current is restore, the light gauge wire should burn out before the battery suffers damage. Be quick - be careful.
Apr 04, 2014 | Electrical Supplies
Electrical diagram for 8000lb champion winch
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Jul 22, 2013 | Champion International Champion 8000lb...
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
[email protected]
Jul 02, 2011 | Champion International Champion Power...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Champion 3500/4000 Watt Portable Generator Logo
102 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
