Question about Lexmark X5495 Printer
Does not print Citrix Virtual jobs. Says "printing" and "printing complete" but does not print.
Citrix printing failure on home printer.
Posted by Loretta on
Gustavo Ortiz
  • 637 Answers
The question is not very clear. The problem could be hardware and not software. I repair a Epson Stylus CX6600 printer with a similar problem and it was a small hose that had come out of site below the inkjet device. I recommend you find someone who can see the printer carefully.
Posted on Apr 04, 2014
5 Related Answers
Anonymous
SOURCE: Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
Posted on May 15, 2007
Anonymous
SOURCE: Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Posted on Jun 16, 2009
Anonymous
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My printer will not print. The print job in the
    Here are instructions on how to delete the print jobs stuck in the queue. Follow the instructions carefully:
    First, you have to stop the Print Spooler. To do this:
    1. Click on the Windows logo start button.
    2. Go to Control Panel
    3. Open Administrative Tools
    4. Open Services
    5. It will pop-up a Services window. Scroll through the list and look for Print Spooler.
    6. Double-click on Print Spooler, make sure Startup type is Automatic and click on the Stop button. Click on Ok button. Set the window aside.
    Second, you need to clear the print jobs in the Spool folder. To do this:
    2. Type Spool in the Search bar(Vista) or click on Run(XP) and type Spool
    3. Open Printers folder
    4. Delete all the files in the Printers folder. Close the window.
    Third, you have to enable the Print Spooler. To do this:
    1. Go back to Services window.
    2. Double-click on Print Spooler, and click on the Start button. Click on Ok button. Close the Services window. Click on the Windows logo start button. Go to Control Panel and open Printers folder. Refresh the page. That should clear the print queue now. Try to print again. If problem is not resolved, maybe it's a communication problem. You probably need to reinstall software. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 17, 2010
    printmastert
    Lexmark
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: LEXMARK 405 COMPUTER SAYS PRINT HEAD PROBLEM AFTER
      You could try reseating the printhead into the Lexmark Interpret S405 printer. But if the error continues, you may need to make sure that your printer's firmware is updated. You can easily download and install the update by visiting the Lexmark website. Click on this link Lexmark Interpret S405 Firmware Update. The update will fix problems related to your printer's printhead.If you encounter any problem downloading or installing the update, please contact Lexmark technical support for assistance.
      Posted on Dec 27, 2010
      1helpful
      Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
      It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
      - type in "NET START SPOOLER" (this will restart the print spooler service)
      Try to print again.
      2answers
      Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
      Follow the steps below to resolve the issue
      The print queue and Dock printer icon
      When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
      You can alternatively open the print queue from the Print & Fax pane of System Preferences.
      printer%20queue.png In the Print Queue toolbar you have these buttons:
      1. Delete - Deletes the selected print job.
      2. Hold / Resume - Will hold / resume the selected print job.
      3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
      4. Pause / Resume Printer - To Pause / Resume the Print Queue.
      5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
      6. Printer Setup - Lets you configure the printer's name and location details.
      7. Printer - Sets the Print Queue window into Printer mode.
      8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
      You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
      From the Print Queue menu bar, the "Printer" menu has these additional options:
      1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
      2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
      3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
      4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
      5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
      6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
      From the Print Queue menu bar, the "Jobs" menu has these additional options:
      1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
      2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
      You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
      printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
      I would like your advice as to how to stop a Printing job before completion on Canon LBP2900B I have been wasting A4 paper because the full job has to run its course even though I wish the job to...
      when printing, you may press the CANCEL button on the printer, right-click the printer tray icon and click view print jobs, then cancel a print job before it completes. you may also want to try specifying only the pages you want to be printed instead of selecting all pages to avoid unnecessary print outs. hope this helps and let us know how it goes.
      2helpful
      2answers
      I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
      for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
      1helpful
      HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
      Does it show "Printing" or "Spooling" in the job queue window?
      Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
      If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
      Don
      HP LaserJet 1022 changes the output order for checks, statements, invoices. Worked fine until 4-5 months ago (we switched over to a citrix server). Have tried reinstalling to citrix and local hard driver...
      It sounds like a computer software issue. However to overcome the problem through the printer you can try this.
      When the screen pop up comes up for printer selection, highlight the printer you will be using, then goto "Preferences". At the top tab click on "Advanced". Go to the bottom of the menu for "Layout Options" and change "Page Order". This should solve your problem, though you may have to change it back to print regularly printed materials.
      1helpful
      Lexmark X5495 Printer Logo
      Top Lexmark Office Equipment & Supplies Experts
      Ekse
      Randy Prevost
      Randy Prevost
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
