You can Find any Sharp Driver From here :
http://www.sharpmea.com/cps/rde/xchg/ae/hs.xsl/-/html/support--downloads.htm
this is the Official Driver's search engine for all sharp products Download Center
you can Find any Sharp Driver From here :
http://www.sharpmea.com/cps/rde/xchg/ae/...
SOURCE: Sharp AR-5316 printer drivers for windows Vista
want to find your driver for sharp ar-5316 for windows vista,you just go to this website http://support.sharp.net.au/drivers/ and u good to go....:)
SOURCE: i want to download sharp printer driver AR
if u ned download manualse and driver softwer see 2 www.givemefil.net every thing is thire
SOURCE: Sharp AR-M550U get error code:F2-31
F2-31 is related to the image process control for the drum. The drum sirface is read by the image density sensor - if it has a problem doing so then it will give this code. Possible causes could be a bad/old/worn drum or the drum is not being cleaned properly by the drum blade. To run the processor control adjustment do the following : press the "P" key then "*" key then "C" key then "*" key again. this will bring you into service mode. (warning : please do not make any other adjustments in this mode as you can do some serious damage to your copier). then type 44 and press start key then 2 and start key again. Once it is finished running restart the copier. If this fails you need to look at the drum and possibly change it.
Testimonial: "very helpfull.Thanks"
SOURCE: How can i download free sharp ar 5316e driver for this due t
Use the below URL
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
