Question about Olympus MJU 400 Digital Camera
Frozen Lens I just dropped poor camera on to the carpet from about a foot! Everything seems to work except the shooting mode, the lens wont extend from the actual camera. The slider still goes across fully and the battery is in fine. I can go into quick view mode and still change settings etc. Is this likely to be expensive to fix?
Posted by dumbtom on
  • Jimlfixitnot Nov 11, 2007
    yes I have the same issue, I assume it maybe linked to the small microswitch situated behind the lens cover. I was hoping it was just due to dust or dirt but no. Can anyone provide any insight into fixing this problem???
Jimlfixitnot
I initially went back to the manufacturer - Olympus at [email protected] found on the website www.olympus.co.uk.
They responded with an offer to repair the camera even though it was out of warranty. they requested me to send it off to them at the following address, where they would evaluate and quote for the repair work.
Olympus Service Department
PO Box 2288
Watford
Herts
WD18 1JS
Alternatively, I could try to source the spare parts or an estimate for repair from Luton Cameras on 01582 458 323.
Hope this helps.
Posted on Feb 04, 2008
mehm0riezz
Yeah i am going through the same problem . Do you know where i can get it fixed?
Was dropped. Now will do everything EXCEPT take photos. Lens, display, flash, etc. etc. all work fine. Just no screen image or photo when in "shoot" mode.
Sounds like the CCD or a stuck shutter blade. Try this place: www.CamerasAndParts.com They only service Canons and they are the only place we recommend for the Canons. It's all they work on and they are about half the price of most shops, plus the work is just excellent through them.
May 15, 2014 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have cannon s3is i was in the middle of shooting and the lens started trippin out and it wont go back in and it say lens error reset the camera. how do i do that or what do i need to do to fix...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 23, 2010 | Cameras
Lens error restart camera I have a point and shoot canon sd750; the lens will not retract and i cannot take any photos nor view photos
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I dropped my camera today. Seems like the lense
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 30, 2009 | Canon PowerShot A80 Digital Camera
SHADOW SPOT ON CANON SD1100 DIGITAL CAMERA SCREEN THAT COMES OUT ON PICTURES
The spot is actually on your camera lens. Try taking the battery out while you are in the shooting mode(lens extended) then clean the lens with a lens cleaner and that should solve your problem.
Sep 07, 2009 | Canon PowerShot SD1100 IS Digital Camera
The camera fell off a desk onto a carpeted floor while uploading pics to the computer. Now the lens will not close properly and I keep getting a "lens error" message. Nothing looks cracked. Can this be...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon PowerShot SD600 Digital Camera
Jammed lerns
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Kodak EasyShare C743 Digital Camera
Camera dropped, lens won't retract or expand
You can buy a new A590 for under $110 these days, so the professional repair option may be out. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 24, 2009 | Canon PowerShot A590 IS Digital Camera
Lens
Jan 22, 2009 | Canon PowerShot SD40 Digital Camera
Olympus MJU 400 Digital Camera Logo
89 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
