Question about U.S. Robotics (USR5633A) Modem
CONFIGURE HUAWEI ETS6630 FIXED WIRELESS TERMINAL WITH WINDOWS 7 PRO
1 Related Answer
Anonymous
SOURCE: Dear Sir or Madam I
Go to Devive manager update device driver of the Modem and then creat new coonection , that's is .
(run)-->devmgmt.msc-->select modem-->r.click-->Update driver-->choose .inf file from ur modem driver folder.
Posted on Feb 06, 2009
Huawei ets6630 not wirking on windows 7 64 bit
Read carefully manual at http://www.huaweidevice.pl/products_solutions/device/ETS6630-1.pdf and install it`s application and driver in compatibility mode with vista or Win xp ...can read also instructions from here: http://ukblog.im-mobility.com/configuring-huawei-ets6630-fixed-wireless-terminal-internet-access
Apr 13, 2014 | Office Equipment & Supplies
Huawei ets6630
Hello plz NCK Code for Huawei ets6630 Imei 356064022688077(vodafone spain )
Dec 03, 2013 | Computers & Internet
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
I have huawei ets2558 with cable usb - rs 232 TUSB3410 but is not working with windows 7
found this solution on scribd.com
http://www.scribd.com/doc/23712717/Installing-Huawei-Modem-Driver-of-PTCL-v-Wireless-on-Windows-7
Apr 17, 2011 | Computers & Internet
Get Message - "Windows cannot configure this
Odds are you have some other software that is over ridding the Windows wireless configuration utility. Look in the bottom right hand corner of your screen near the clock and check each program listed there to see if there is another wireless configuration program running.
Feb 28, 2011 | Intel PRO/Wireless 2100 MiniPCI 802.11b
How to configure the modem HUAWEI WIRELESS MODEM 153.6K in windows 7
Lookin 4 da answer too and this stupid site seems too full of spam,hoax's and adverts that ther aint anything helpfull.. gotta go look further cya
Jan 14, 2010 | Computers & Internet
I need driver for Windows Vista/7 x64 or x86
you can take it by internet or any computer vendor.
Oct 31, 2009 | Computers & Internet
I want the driver for huawei fwt wireless modem
I'm giving you two links to download the drivers for Huawei fwt wireless mode
1- http://www.openpages.info/huawei.html and
2- https://answers.launchpad.net/ubuntu/+source/wvdial/+question/43266
You will probably need to edit the wvdial.conf file a little so that you are using the right connection parameters for your internet service.
If those URL's did not help, please follow this procedure:
Step 1: Open Terminal from "Applications->Accessories->
Terminal"
Step 2: Run the following commands (copy-paste each line below to the Terminal then hit <enter> after each line)
ifconfig
sudo lshw -C network
lspci -nn
lsusb
uname -a
dmesg | grep USB
Step 3: Post results (cut/paste terminal output from each command) here
Step 4: Provide us with the full model and make of Huawei modem. What is the exact model number? Does it connect to the PC using a serial-to-USB converter?
Apr 19, 2009 | Computers & Internet
Dear Sir or Madam I have a TUSB3400 HUAWEI ETS2058/2258/2558 fixed wireless terminal and i also have a vista os with windows x64 system,now i cannot insyall the driver for this wireless modem please try to...
Nov 22, 2008 | U.S. Robotics (USR5633A) Modem
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
U.S. Robotics (USR5633A) Modem Logo
87 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Barbat Nae
Barbat Nae
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
