Question about LG 50PX5D 50 in. Plasma HDTV
LG Plasma 1080p 50" T.V. Television. Model 50PS11 has sound but no picture
Sound and no picture
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Posted on Feb 10, 2009
Anonymous
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
Anonymous
SOURCE: LG 50PX4DR plasma tv
I had the same exact problem as posted above. My 50" LG plasma was out of warranty for 1 year! I called the LG executive call center, and they were very helpful. They offered to pay for the parts and labor. They recommended a few local repair shops, and they set everything up for me. The tech came out within 4 days with one part. The tech had to come out one more time the following week, since more parts were needed for the repair. The Y sustain board, along with 2 adjacent parts that are required to be replaced as a set, and the power supply had to be replaced (parts alone cost just over $900). TV is like new again; I'm very happy with how LG handled it, and made what could have been a bad experience a good one.
Posted on Apr 30, 2009
David Low
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
I have a lg 50" plasma tv with a distorted, discoloration. The model number is 50ps11-ub. Not sure what circuit board/panel to purchase. Can you help me with this? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 27, 2016 | LG Televison & Video
How do I fix LG plasma has sound but no picture?
If you using a TV box (Example, Telus) the best bet would be you connected everything together correctly, and make sure that all the wires are connected in the right sockets
Apr 29, 2016 | LG 60PA6500 60" 1080p Plasma TV - 16:9 -...
Why is my lg plasma tv top half screen black?
electronic board fault , usually cracked solder joint see the liink below for more details
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 31, 2016 | LG 50PS11 50 in TV
My 50 inch plasma tv has black lines appear in picture
The issue could just be with the signal cable. Make sure the cable is not loose. Also try replacing the cable if you have an extra. If the lines disappear it could also just be an issue with the plasma, it may get worse over time, but don't worry about it for now.
Apr 09, 2014 | LG Electronics 50PG30 50" 1080p Plasma TV...
LG PLASMA TV MODEL 50PC1D NO PICTURE
This is a Plasma TV. Manual can be downloaded here , LG UK , I am sure there is a US also ..
http://www.lg.com/uk/support-product/lg-50PC1D#
Sep 20, 2012 | LG 50PX1D 50 in. Plasma Television
LG 50 Plazma 1080P picture too tall in all modes
minha plasma de 50 assistindo apagou a imagem e so aparecia o so tem alguem para me dar uma sugestao
Nov 06, 2010 | LG 50PS60 50 in. Plasma HDTV
How do I colourwash my LG Plasma TV model LG 42PC55
In the menu selection you should have something in the options called ISM Method. Set this to "color was" to wash colors out, then use the white wash to get the ghost out. It is also recommended that you use your plasma at 50% contrast as the gas used to display color needs time be evenly worn down. I have a brand new 50" LG 1080p full HD 600Hrz that I bought last month, and I already have burn in because I didn't read the manual. Make sure you're using the orbital setting during the first 200 hours as well this will reduce the intensity of the burn.
Feb 20, 2010 | LG 42PC5D Television
Lg plasma after storm doesnt want to turn on
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PC1DRA 50 in. Plasma Television
LG Plasma television
ya return it then asap ok cheak out samsung way nice t5054 model ok this ones know for issues
Feb 11, 2008 | LG 50PX1D 50 in. Plasma Television
LG 50PX5D 50 in. Plasma HDTV Logo
150 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
