Question about Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW
Running hiren boot norton ghost backup, laptop suddenly going black screen and shutdown
When i am running norton ghost backup using pendrive, it will shutdown the laptop suddenly after few minits running
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: 1. First trouble was screen
It's your NVIDIA GeForce 8400M GS graphics card. There a design flaw that I can't find out if it's been corrected. Customer support only replaces the motherboard with the same problem. They won't sell just the GPU card off the main board. This has been pissing me off for 3 or 4 months now. Can't seem to get any help from anybody.
Posted on Sep 25, 2010
I can not detach my IBM Think pad 2662 lap top from the driver
I had the same issue. Here's what I did. Not sure if it will work for you. But give it a try.
1) turn on the machine and press "F2" to go into set up.
2) Press alt-p seven times to go to the last page.
3)Press the down arrow to highlight HDD password. Set a password as instructed and reboot the machine.
4) You can remove this password later once your machine starts fine.
Even if you didn't get try this too.
1. Make bootable CD which contains Norton Ghost or other disk image software
2. Boot your system using bootable CD with Norton Ghost software, u can use Hiren's CD ISO image. If u don't know about hiren just google it.
2. Once you boot up , open Norton Ghost click LOCAL-> PARTITION->FROM IMAGE
3. Now "look in" for "[DellRestore]FAT drive" and select this drive (this is recovery partition)
4. Now go to "IMG" folder and select FI.GHO file
5. Click Open and there you go... Process started
I HAVE AN EEE PC AND KEEP GETTING AN ERROR MESSAGE SAYING 'EEE PC TRAY UTILITY HAS ENCOUNTERED A PROBLEM. ERROR TYPE:BEX P1:AsTRAY.EXE P2:5.1.13018 P3:4886b209 P4:AsTRAY.EXE P5:5.1.1.3018
first make a image of the partition using norton ghost. (you cand find it on a hirens boot cd), next uninstall the tray utility. if it is still the same problem, try reinstalling the operating system. if not reinstall the utility and see if it works. if it doesn't works and you don't want to reinstall the operating system, remake your partion from the image created initially using norton ghost
I need to upgrade HD for dell inspiron 9400. How can I copy old HD keeping original factory config?
Download Hiren's disk and on teir their are heaps of cloning tools. My favourit is Nortons Ghost. This will make an image of your hard drive and burn them onto a dvd for you and once you have done that install your new HD, boot of the Hirens disk, start Nortons ghost then burn the image of your old HD onto the new one and then you can continue your computing from where you left off from.
How to restore the computer using the norton ghost
Use your Norton Ghost boot disk to boot your computer.
Once it's booted it will ask you what you want to do.
Choose to Restore your harddrive and point to where the image is residing on your backup.
It's all pretty self explanatory. It may take several hours, so be patient.
1helpful
2answers
I have XP on my computer with 2 hard drives. one for a backup. Can I copy one hard drive to the other? If so what is the proceedure. thank you.
yes.right click my computer and go to manage. now select the partition to delete and right click and click delete. then there would be unpartitioned space. now right click c drive and click extend. its done
1helpful
I want to change the HD from 40Gb to one with more capacity but I tried to make a ghost image in a 120GB and 160GB HD but the bios don't recognize it and only can see in the screen a simbol _ flashing.
Not sure which software you are using for making the ghost image. Lets say its "Acronis".
First, you will need an USB hard disk drive to store the image on.
Next, run the boot cd and choose backup.
Send it to the hdd.
If it was successful, remove / replace your hdd.
Run the boot cd again but now choose "Restore". Locate your image and then wait.
Hope this helps you. Norton Ghost is a bit different.
1helpful
Don't know how to restore files from backup done with North Ghost
Using Norton Ghost 9.0 is very good program to backup your System & Documents.
You said the PC is dead then you want to restore back your System to a new PC.
All you have to do is that Norton Ghost 9.0 CD is Bootable.
Of course also your external hard drive are plug in it too.
Manually you're going to open that Sv2i file to restore back again your old system but there are some programs that are not going to use. Like for example: System Drivers (Motherboard Driver, LAN, SOUND, etc.) but at least you have the Documents and the rest of the programs run again.
I try it myself this kind of situation, I'm using Windows 2000 with Norton Ghost 9.0 version, and it's 100% works. Good luck!
Hope i might give you some tip & idea.
Tell me more about if you got a problem.
Please rate me.
Thank you.
1helpful
One key recovery is deleted
if you mean to restore the one key recovery
copy the one key recovery partition from other laptop with Hiren all in one Cd
http://www.hiren.info/pages/bootcd
inside the cd you can found norton ghost
run it
then choose the operation
choose partition
choose to image
save to any partition
then proceed the image creation
then copy the file *.gho
to your hard disk drive
then make a partition that at same size with the one click recovery partition
then run again norton ghost at hiren CD like before
choose partition
choose from image
designate where the .gho file is located
then follow the prompt
------done------
2answers
Removing norton ghost before reinstalling
If you tried removing Ghost yourself by deleting foulder or files then it will not appear in the add/remove list. Try reinstalling it and then using removal tool. Make sure you have correct one for version and your OS. My advice is stay away from Norton products, they severely slow down performance and hinder daily activities. There are free tools online that work much better.
Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW Logo
Top Averatec Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
