Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Need canon drivers for my computer
Can not transfer pictures to my laptop. The computer does not reconize the camera usb
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Posted on Oct 04, 2014
5 Related Answers
Anonymous
  • 1550 Answers
SOURCE: I nead usb driver for canon digital camera ixy
You can get from the link below
Driver for canon digital 200
Hope this helps .
Posted on Mar 03, 2009
Anonymous
  • 8 Answers
SOURCE: how to transfer pictures from my Canon PowerShot
There are two ways of doing this:
  1. Install the software on the CD that came with the camera, then use the USB cable that came with the camera to connect it to the computer. The software should walk you through the rest of the process.
  2. Buy an SD card reader (example Card Reader from Amazon.com), connect it to your computer, and take out the SD memory card from the camera, and insert it into the appropriate card slot on the card reader. Then use whatever photo management software to manage your photos.
I would recommend the second method since it reduces the wear and tear on your camera and allows you to access the photos easier through Windows Explorer or Finder (MacOS).
Hope that helps!
/davey
Posted on Oct 20, 2009
Kuwagata
donny ardalando
  • 208 Answers
SOURCE: Problem transferring pics with the Canon Powershot SD750
Replace the USB cables, it should work..........
Posted on Dec 08, 2009
Anonymous
SOURCE: Canon Powershot SD1000 Uploading Pics To Computer Problem
ugh this happened to me too :( it sucks cuz i have had great pictures i wanted to upload but they wont upload :(
Posted on Jan 01, 2010
fathitkf
Fathi Elmahdi
  • 1871 Answers
SOURCE: Canon Ixus 960 IS Driver Problem
Hello :
This link contains the right driver for your CANON DIGITAL IXUS 960 IS .
PLEASE DON'T FORGET TO RATE !
GOOD LUCK .
Posted on Apr 08, 2010
How to transfer photos from canon EOS rebel t5 TO laptop
switch off camera , connect to laptop with usb cable, turn on camera, drop down window will ask what to do with photos. If no window , click on start, click on computer, your camera should as a drive , right click and click open on the drop down window .
May 04, 2018 | Canon Cameras
Cant transfer pictures to computer
Try NOT connecting your camera to your computer.
Apr 04, 2014 | Canon PowerShot SD750 / IXUS 75 Digital...
Why does the usb connection not reconized?
Have you tried NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
As to why your USB connection isn't working, there are a lot of possibilities. You may not have the right driver. If you're going through a USB hub, you might try bypassing it and connecting directly. There could be something wrong with the cable. There could be something wrong with the computer's USB port. There could be something wrong with the camera's USB port.
The main reason camera manufacturers include a USB port on their cameras is not so you can use it to transfer photos. They put it there because other manufacturers put one on, and so the marketing department insists they do so as well.
May 09, 2012 | Canon PowerShot A720 IS Digital Camera
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Apr 14, 2010 | Canon PowerShot A430 Digital Camera
Cannot transfer pictures from CX7330 to computer. Worked fine about a month ago.
I have a Canon PowerShot A720 and have lost the disk to download drivers so I can get the photos off of my camera. Do you have any suggestions. I have tried to find them on the internet with no success. Help Please!!
Jun 10, 2009 | Canon PowerShot A720 IS Digital Camera
Drivers for a canon s330 powershot
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Some Canon camera is not Vista compatible and cannot work on Vista.
Dec 06, 2008 | Canon PowerShot S330 / IXUS 330 Digital...
Transferring photos to computer
see first urs usb cabel is well fitted in urs pc or not or wid camera.....
if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader...... but usin carrd reader u can only transfer urs memory card pics... n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not....
ask me if it creates more problem.....
thanks...
Jun 23, 2008 | Canon PowerShot A520 Digital Camera
Downloading pictures
I think the USB driver in your laptop is malfuntioning.
Try the following step.
1. Press windows+Pause Key
2. Click on device manager
3. Check if there is any ? sign in USB drive.
4. If it is so, right click on it and click on update the driver
Dec 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
