Broiler & stove work but oven will not bake. just had the baking element replaced
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
SOURCE: Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
SOURCE: Kenmore oven wont work
Hi, The most common issue when the oven doesn't work is the ignitor. You can open the door and remove the floor panel inside the oven. Start the bake and see if the ignotor glows. It probibly will but, that doesn't mean it is ok. It just means the ignitor is getting voltage. When the ignitor is glowing, you can try (BE CAREFULL not to be to close to the buner) and tap on the side of the gas valve with the handle of a screwdriver. If the gas ignites, you will need to change that ignitor.
Again, this is very common.
Please let me know if this helps you or if I can assist you further.
Vic
SOURCE: kenmore oven doesnt bake
Can I assume that you determined that the bottom burner flame is burning properly? To do this, remove the oven bottom insert. The flames should have approximately 1" of blue cone and should burn with no yellowing tip, if on natural gas. (A small yellow tip on the end of the outer cone is normal with most LP gas.) The flmaes should not lift off the burner ports. If the flame is lifting, gradually reduce the air shutter until the flame stabilizes.
Go to the following website for your particular manual.
http://www.hammerwall.com/Manuals/Kenmore/Description/362.75585890/Kenmore%20Free%20Standing%20Gas%20Range%20Owners%20Manual/L0522834/
SOURCE: I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
SOURCE: I have a Kenmore Ultra Bake oven. Broiler wont
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
