Question about Canon LV-5210 Multimedia Projector
Projector turns off
When the power button is pushed the fan comes on, then the fan gets louder and the power button  flashes red and green for about a minute and the projector turns off.  The warning and lamp replacement lights never come on and the lamp never comes on.
Posted by mac33 on
  • 2 more comments
  • annarella May 27, 2008
    I have the lv-5210 Cannon, and I have the same problem, I have replaced the lamp and still nothing. No lights or anything. Driving me up the wall.
  • Anonymous Dec 10, 2008
    Canon LV-5210 -- I turn it on, the light flashed green, then red for about a minute and then it shuts off. The lamp was replaced 6 months ago and has definitely not been overused. I read the response about pressing the reset button on the back of the projector. There is a spot that says reset and a hole below it, but no actual button. When I push something inside, it just hits a wall. Please help!
  • Anonymous Feb 04, 2009
    I have the exact same problem. There is a hole for reset but no button. Also, my lamp is only 6 months old and not overused. Does anybody know what the problem is with this?
  • Anonymous Dec 20, 2009
    I am still having this problem and unable to find a corrective solution. I even spoked to a Canon Tech who suggested replacing the bulb, at $629 a crack, I don't think so!! My bulb was only 6 months old and definitely NOT over used. DOES ANYBODY KNOW THE ANSWER TO THIS????
Anonymous
Still looking for answers....anybody????
Posted on Jan 24, 2010
Anonymous
    Problem Solver:
  • 5 Answers
Hi there may i give a shot?
fan sound get lourder......that is normal after start up
check the bulb
check the filter
restart the projector reset button back of projector
Posted on Jul 10, 2008
Anonymous
Mpsoi said "check the filter". He should have said, "check the filters." I can't find my User manual, but I found the filters by examining the underside of the box, after the box had coolde for 45 minutes,of course.
You do the same. Turn it over on a newspaper or something, study the bottom. Notice two long lines of dark grey plastic running parallel to the long side of the box. One is about 2 inches long and is right near the lens. The other is about 4 inches long and runs near the back edge of the box. These grey lines have little doogerhitchies in their middles, so you can pull them out with yor fingernail. Pull them out. Clean them over the sink or outside. If you got 'em wet, let 'em dry real good before putting them back. Then put them back. It's all real easy once you find those two lines.
Posted on Jan 17, 2009
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Canon LV-5210 Multimedia Projector Logo
433 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
