Question about Juicers
Mercury T605 juice extractor
Having a problem figuring out how to clean blades. The unit opens but the blades do not detach as far as I can tell. Do not have manual & can't find online instructions, please advise, thanks.
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: manual for an OscarJuice Extractor ?
Here the manual for Oscar 900 that is quite similar, the operations and recipes should be the same.
Posted on Feb 24, 2009
Anonymous
SOURCE: Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Posted on Mar 02, 2009
Anonymous
SOURCE: OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Posted on Apr 26, 2009
Anonymous
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Posted on Jul 12, 2009
JOHN REILLY
  • 356 Answers
SOURCE: Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Posted on Apr 04, 2010
When i juice greens i am no longer getting any juice from them. is my blade dull?
If you mean green leafy greens, the juicer is
not really designed for them. A sharp blade
will extract some juice from them, but I found
a new blade seems to increase the vibration
issue. Acme works best on carrots, apples,
celery, etc.
Oct 25, 2010 | Acme 5001 Supreme Juicerator Juice...
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
I have a Krups Vitamight model 294 juice extractor. My son used it and now I can't get the pulp container off. I have never used it and the the manual is gone.
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
Nov 20, 2009 | Krups Juice Extractor
Waring juice extractor pulling to one side and vibrating
I would say you are right. The blades are dull & or
the balance of the motor has become lose or broken free. A broken blade can also through balance off.
Replace or repair.
Mar 08, 2009 | Waring Pro Juice Extractor -...
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Rival juice extractor model 965
Jul 15, 2008 | Juicers
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Juicers Logo
194 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
