I've checked the manual but could finf if your on/off knob is by a pcb tiny on off knob or do you really year a hard click. http://www.vinylengine.com/library/numark/tt1510.shtml login and they know it, it's easy to make
Try pressing the power button for several seconds (10-15). It should power off the laptop. If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
It must be hard for you having this issue. Here, do these steps correctly, it will help you fix this issue.
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button twice then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should work normally.
Thank you for visiting FixYa! I really hope I made your day! Enjoy!
Hello
Remove the error code 5100
1. Turn off printer.
2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
3. let go button Stop/Reset, continuing to hold POWER.
4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
6.turn off printer by POWER button, then turn on.
7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution
Good Luck,
Cmptrlink
Hello Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work! Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
