Question about Windchaser Stainless Steel Patio Heater 40,000 BTU by - Model PHS
Bent vertical post - Windchaser Stainless Steel Patio Heater 40,000 BTU by - Model PHS
How to achive 90 degrees rear wheel of a mobike?
exactly what do you mean by this ?
are you saying that when the bike is vertical that the rear wheel is at an angle to the road and not vertical as is the frame
If that is the case the rear suspension swing mounts are worn out , frame is bent for the rear wheel or if the wheel only has one swing arm , that is bent
Jan 11, 2018 | Cars & Trucks
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
The dryer door is sagging and is hard to shut
Hello. Probably the hinges are worn/bent. And, the door could be bent from leaning on it, resting clothes on it(if it opens/closes vertically). Also, if it is bent enough, the strike/catch might be mis-aligned and not holding properly.
Aug 13, 2015 | Dryers
The letter F when capitalized give me this character I I (actually does not look like that but just two vertical lines) doesn't do this on the lower case and it is only the F
You have either a bent of broken spoke on your print wheel. If it is bent you may be able to fix it. The vertical lines are the hammer face.
DickyO
Oct 21, 2014 | IBM Wheelwriter 6 Typewriter
Olympia Startype 3 occasionally types double vertical line and spacing is changing between letters
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
Sep 15, 2014 | Olympia Startype 3 Typewriter
Toshiba 42h83.... The blue convergence will not line up. The horizontal will but the vertical will only move so far. when touch focus starts the reds and greens are perfectly strait the blue vertical is...
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Toshiba 42H83 42" Rear Projection...
Hello! My typewriter types two vertical lines instead of capital A letter, how can I fix these problem?
The spoke on yuor printwheel is probably bent or broken. A new P/W would be best but if it is bent you may be able to align it.
DickyO
Nov 18, 2010 | Brother SX-4000 Typewriter
Heating & Cooling Logo
21 people viewed this question
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
