SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
SOURCE: Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
SOURCE: one handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
SOURCE: The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
