Question about SanDisk Sansa e250 MP3 Player
Looking for a e250 Sandisk Sansa lcd plz
do you perhaps know from where i can source E250 Sansa LCD from.
I would really appreciate some help, i've looked just about everywere.
If you have an idea about price and availability please could you contact me
Hendrick
[email protected]
Many thanks in advance
Posted by Hendrick on
ThaMp3Doctor
  • 8,597 Answers
Check eBay - it's a lot easier than posting to a tech forum and waiting for a response
Posted on May 26, 2008
I lost my software for my mp3
Hi
I see that you need the driver for your Sansa Sandisk e250, see links below for the download page.
http://kb.sandisk.com/
This will direct you to the Sandisk website just select your Sansa e250 from the list of devices from the website to get the driver softwarethat you need to make your Sansa e250 running.
I hope this helps.
Have a nice day,
mvincentc
Apr 27, 2011 | SanDisk Sansa e250 MP3 Player
My sansa screen
replace your sansa.. i think the lcd is damaged already. im sorry.
Jan 27, 2009 | SanDisk Sansa e250 MP3 Player
A problem with my sansa e250..help here please..
That one time happend to me. I plugged it into another port, and it worked fine.
Jan 22, 2009 | SanDisk Sansa e250 MP3 Player
Cracked screen LCD
Hello shaffycat,
Sorry to hear about the screen on your Sansa E250 MP3 player. It sounds like the Liquid Crystal Display screen has broken. It's possible that the damage is repairable but to be honest due to the high cost of electronic repair it may not actually be cost effective to do so.
You can contact SanDisk to get service information. They can give you a basic idea of what it would cost to get an estimate on repairs and the average cost. Their webite is http://www.sandisk.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Hi shadow5991,
have you tried the Sandisk website? It has a forum that contains a lot of information. Your answer may be awaiting you in the forum.
To me it sound like a configuration problem. It's looking for files on it's internal memory and maybe you've put them on a SD media card? When plugged into the PC it does perhaps it reads all sources?
Regards,
Spare head 2.
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250
You need to use the Sansa Media Converter to convert and copy photos to the e250.
It is here;
http://rapidshare.com/files/67741182/sansa_media_converter.zip
Its fairly simple to use.
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | SanDisk Sansa e260 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
Help!!!!
SAME THING HAPPEN TOME NEED HELP
Mar 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
