I have just put a new sdhc card into my digimax s500 camera tried to take a picture but no image shws when trying to delete ir
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
SOURCE: When I try to take a picture "Card Locked!" shows on the screen
if you have a memory card in the camera then the card is locked lol...take the card out and with the front facing you on the right side there is a little piece of plastic attached to the card....it will slide up or down and snap into place in either direction...if the camera is sayin it is lock then slide the plastic piece in the other direction and let it click into place and u should be able to save pictures to it
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
SOURCE: When I try to turn
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
