Question about Samsung Digimax S500 Digital Camera
Sdhc card will not load onto my samsung digimax s500
Sdhc card will not work on my camera format appears on screen but when I ok it nothing happens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The S500 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Posted on Apr 16, 2014
5 Related Answers
Parshiv Luthra
  • 395 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
Anonymous
  • 12 Answers
SOURCE: Wont turn on, power light just flashes and nothing happens
batteries are dead,or not in properly.if not. only use energizer lithium batteries.others burn out very fast,hope i was helpful.
Posted on Apr 14, 2009
Anonymous
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Posted on Apr 23, 2009
pickmynose
  • 161 Answers
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Posted on Sep 09, 2009
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
OlandHill
SOURCE: When I try to turn
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Posted on Jul 12, 2010
Is sony sdhc compatible with samsung digimax s500?
Apr 04, 2014 | Samsung Digimax S500 Digital Camera
How do i format the memory card on the kodak easy shareDX7590. I just bought and inserted a knew kodak 8 gm memory card and it says it need to be formated and i do not know how and have pushed all the...
To format a memory card, press the MENU button, use cursor-up/down to select Settings, press the OK button, use cursor-up/down to select "Format," and press OK.
The DX7590 works with MMC and SD cards. It does not work with SDHC cards. If you mean an 8GB card, then that's an SDHC card and will not work with the DX7590. The camera is limited to cards 2GB and smaller.
Sep 24, 2011 | Kodak EasyShare One Digital Camera
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
I am using a sd card ,which I used with my Samsung digital camera , and the kodak is telling me to format the card. When I try to reformat the card nothing happen it keep going to screen to reformat card....
If the card is more than 1GB it is probably an SDHC card. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 01, 2010 | Kodak EasyShare C743 Digital Camera
I have a memory card error appearing on my camera. My camera is ok just the memory card as i have tried using another card in my camera. It happened last night after taking photos when my battery was low....
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jul 30, 2010 | Canon IXUS 80 IS Digital Camera
Memory card needs formatted is displayed on the screen. Deleted the pictures and it still comes up. Tried to take more pictures and the memory card would not hold. Is there something wrong with the camera...
I assume you have an SD card. If it's bigger than 2GB then it's actually an SDHC card and will not work in the ZD710.
No, there doesn't seem to be anything wrong. The card just needs to be formatted. In any mode press the Menu button. Press right-arrow to select the Setup tab (camera and wrench) then press OK. Press up/down-arrow to select "Format" then press OK.
Make sure you format the memory card. It's okay to format the internal memory, of course, but your current problem appears to be that the card needs to be formatted.
May 28, 2010 | Kodak ZD710 Digital Camera
"Format the card" appears in the screen and I can do nothing! "Format" or "Full Format", but nothing helps
Have you actually tried to format the card in the camera and you still get these messages?
Aug 14, 2009 | Sanyo Xacti S5 Digital Camera
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Samsung Digimax S500 Digital Camera Logo
67 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
