Question about Sharp AR-5516s
Error cod f2 ar 5518 - Sharp AR-5516s
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
Anonymous
  • 13 Answers
SOURCE: My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Posted on Oct 30, 2008
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
mpn16
  • 6 Answers
SOURCE: error F2 on a sharp ar-5132 B?W copier
i am getting 32
Posted on Jan 04, 2010
Rick Kasper
  • 2072 Answers
SOURCE: Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Posted on Aug 03, 2010
Sharp 5518 error cod f2 and 40
Toner cartage eroor Repalce toner sensor
Apr 27, 2014 | Sharp AR-5316 Advanced Digital Imager...
5518 advanced clear
check fusing unit first and then reset error code.
Sep 19, 2013 | Sharp AR 201 Copier
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
How can i reset the sharp ar-5518 sistem
how we can for the first time set sharp 5518 copy machine
May 16, 2011 | Sharp AR-5316 Advanced Digital Imager...
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR-5516s Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
