Motorola Mobility RAZR V3i Cellular Phone Logo
Question about Motorola Mobility RAZR V3i Cellular Phone
My pc not consider my mass storage device
Not showing my photo &vedio
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Which mass storage device asus eee1005ha is?
The harddrive
(A USB thumbdrive is a removable mass storage device.
An external harddrive is a removable mass storage device.
A harddrive is a mass storage device that is installed IN the netbook.
NOT considered removable, therefor the one mass storage device)
Regards,
joecoolvette
Get photos off
If your photos are stored on the memory card, then removethe memory card from the cell phone and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
USB Mass storage...when I want to transfer all my viedo or photo to my computer... in the scream of camera .it`s shows....USB mass storage.... and it`s not posibel... please fine my problem.. thank...
Your PC is seeing your camera memory as USB mass storage and this is OK. Nothing is wrong with this. Follow the screens and you will see that the computer will see your camera as USB mass storage, and when you open the folder on your computer the camera pictures will be there.
Windows is set up to see cameras as USB mass storage devices for simplicity, so your computer can accept pictures from any camera that connects by USB without needing special software.
If this bothers you, most cameras are sold with their own special software that starts when the camera is connected. Check your users manual and follow the instructions for installing or downloading the software.
1helpful
Can't download photos off my phone onto the computer
use the phone in mass storage device mode
go to settings -> pc settings in your phone
select MASS STORAGE DEVICE and save
now connect the phone to PC
it will appear as flash drive in my computer
browse to it and transfer the photos.
How can i upload my photos using a U.S.B cable
if ur phone is attached as a mass stroge device.......then u can easily upload them by opening mass storage driver...........if it's not attached as mass storage then u need a PC-Suite for ur phone
Can't transfer photos from Sony erikssa W 350 phone to dell laptop. computer recognizes conection to phone but wont get the photos
Make sure the phone is set to mass storage device. you will see your phone once it is set to mass storage device in the my computer window as another hard drive. it should say removable disk in the my computer window. Just remember when you plug the phone in, make sure you set the phone to use as mass storage device.
Mar 16, 2009 • Cell Phones
2helpful
How can i download pictures on my SGH-G800 to my computer?
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu
- Select Settings
- Then Select Phone Settings
- Choose PC Connections from the menu
- And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
2answers
TRANSFORMIN PHOTOS FROM OLD CELLL PHONE
How can I transfer files between my PC and my phone? space.gif space.gif answer.gif To tranfer files between your PC and your phone:
  1. Your phone can upload and download files when connected to a PC running Windows 2000 and higher. Mac is not supported.
  2. Open the flip and turn the phone on.
  3. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  4. On your phone, press Yes to use the phone as a portable USB storage device.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon
  6. Double click the Mass Storage Device icon.
  7. Drag and drop files between your computer and phone
  8. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware" icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  9. Select USB Mass Storage Device and click OK.
  10. Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts.
Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
1helpful
2answers
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
  6. Select USB Mass Storage Device and click OK.
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
Steve
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
