Question about Polaroid TLA-01911C TV
Fix sound on Polaroid TLA-01911C TV
All of a sudden, we have no sound on Polaroid TLA-01911C TV. We have checked connections, powered off and un-plugged for a few days. Blown out interior of TV with hair dryer. Now if remote has sound all way up to 100, we can hear a tiny bit of sound. We want to know what to do to get sound back with remote on normal level. Many thanks - oneofeachmom
Posted by Karen White on
Mike M
  • Polaroid Master
  • 3,324 Answers
Audio amp may be blown. A cable may be bad.
What are you connected to?
Posted on Apr 04, 2014
Testimonial: "Mike M, we are connected to Time Warner Cable. We have GREAT picture but lack sound. Any ideas?"
  • 6 more comments
  •  Mike M
    Mike M Apr 07, 2014
    Aside from the obvious, that you have not got the mute function pressed on either your cable remote or your tv remote...How are you connecting your cable box to the tv? Do you understand that giving all the information to begin with is much better than me having to drag it out of in a series of questions?
  •  Mike M
    Mike M Apr 07, 2014
    Every connection and every device being used needs to be known. Makes, models, everything.
  • Karen White
    Karen White Apr 08, 2014
    Okay, TV is connected to a Time Warner Cable - NO BOX, and plugged into electrical outlet. Cable was just here and replaced cable, put on noise filter to reduce feedback on our NON-box tvs. None of this worked. If you need make of actual cable...let me know.
  • Karen White
    There are no devices attached to tv, except for TWC cable.
  •  Mike M
    Mike M Apr 08, 2014
    OK. Sorry this is taking so long. Do you have a smaller tv you can connect to the TW outlet? This would prove whether it is the TV or not. Or, do you have rabbit ears to try on the Polaroid TV? There are settings on the TV that select sound input and output. Have you checked them? The TV remote should have a menu for these settings.
  • Karen White
    This is our smallest tv. No luck on rabbit ears either. We've gone through every setting on menu. Even selected close caption, then turned it off. When tv has been off for awhile, we'll hear staticky sounds like sound is trying to come back. Other times sound is perfectly clear, but can only hear tiny bit when sound level is on 100.
  • Karen White
    Reviewed online manual but alas...no troubleshooting section. Want to gain access to interior of tv...but wouldn't know what to do once inside exposed.
  •  Mike M
    Mike M Apr 08, 2014
    Take it to shop or call a repair service. Audio amp is blown. Is there a headphone jack to try? Or external speaker connections?
5 Related Answers
Ron Treat
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
Caleb Judd
  • 157 Answers
SOURCE: I have a polaroid lcd tv model TLA
Can you see a very faint image? the backlight may be dead. otherwise it could be a number of things.
Posted on Jun 16, 2009
Anonymous
  • 19 Answers
SOURCE: Polaroid TLA-01911C TV - I seem to have the same
I had the same problem - replaced the capacitors which cleaned up the signal. Then I hear a "buzzing" from the CCFL lamps. Turns out the solder job on the CCFL's themselves was shoddy and corroded. No good CCFL Power trips the inverter and turns the lamps off. Resoldering the wire to the end of the CCFL's fixed the problem permanently.
Posted on Dec 08, 2009
Anonymous
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
Anonymous
SOURCE: hi polaroid tla-01911c white screen
polaroid LCD has white screen and no sound
Posted on Jan 11, 2011
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
Feb 16, 2012 | Polaroid TLA-01911C TV
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
May 07, 2011 | Polaroid TLA-01911C TV
I have a polaroid TV model # TLA-01911C. It has sound but no picture. Just black screen.
Check the power supply and the voltage feeding th baclight inverter board.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=TLA-01911C
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 12, 2010 | Polaroid Televison & Video
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Hi my tla-01911c tv powers on and displays the polaroid logo on the screen for about 30 secounds then shuts down as if there is a power overload or something. any ideas? thanks
Either the power supply/inverter board is bad, or the bulbs are bad - or poorly connected. In my case, the solder joints at the end of the bulbs in the top and bottom were horrible. A quick resolder on the corroded bits and good as new.
Dec 20, 2009 | Polaroid TLA-01911C TV
I had the same problem. I replaced 14 capacitors on the Power supply board. I used Panasonic FC series. You could look for swollen capacitors or ones that are oozing. For sure replace these. My set had capacitors that are known to cause problems so I replaced all of them even though I saw no swelling of oozing. Be sure you label all connections carefully when you disassemble.
Jan 17, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Nov 08, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV Logo
250 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
