SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
SOURCE: grinds coffee but no water comes thru
Sounds like the grinder is grinding too much coffee than the brew unit can handle. Otherwords itis overloading the brewunit. Try reduce the aroma in the coffee menu to mild.
SOURCE: My Saeco Incanto machine grinds the coffee, makes
Hi
There are 2 knobs in the bean hopper. The small knob is turned to the max (+) side and needs to be turned back 1 mark, then try again.
SOURCE: My Royal professional cappucino machine
Hi
There is a lever at the top of the door on the right side. Pull the lever back 1 notch from the plus (+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge. The lever in on or behind the door, NOT under the bean hopper!
Also if the grind is too coarse (french press) this can also do this, and that means that the grinder has seperated. New grinder.
