Question about Canon PowerShot SD1000 Digital Camera
Canon elph lens cover won't open or close
Dropped camera, cover of lens came off & black bits, put back, lens retracts in and out, but the two black "cover arms" won't move to close to protect the lens
5 Related Answers
Anonymous
SOURCE: My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Posted on Mar 23, 2008
Anonymous
SOURCE: canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Posted on Jun 24, 2008
SOURCE: lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Posted on Jun 17, 2009
Anonymous
  • 477 Answers
SOURCE: Canon g9 Camera was dropped. Now lens will open
Yes it is the lens is exspencive but it canbe replaced. cost on the lens is about 150.00 for parts and labor. could be more or less at other digital camera repair shops.
Posted on Jun 26, 2009
Anonymous
  • 164 Answers
SOURCE: Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
How do i fix a Lens error in canon powershot elph 300hs?
None of the suggested solutions worked for me and my Elph 300HS. However, I took it apart, removing the back. There was a screw inside holding on the front panel which I could not budge no matter what, so I gave up. I put it back together, reinserted the battery, powered on and voila, it was back to normal. Perhaps disconnecting the battery for a while was key. Had I not tried the multi-step approach suggested, it would still be stuck.
Feb 23, 2012 | Cameras
When i turn on my camera it beeps and the screem goes black saying.... Lens Error, Restart Camera.. how do i fix this?
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Apr 03, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I dropped my Powershot SD 500 and now the lens cover does not cover the lens. It leaves a gap when closed and does not retract all the way when open. It seems that the resolution on some of my photos is...
A bit of gentile persuasion may be necessary.
Have you tried to push the lens into the camera body?
I believe that the camera has lost track of where the lens is in it's range of travel.
use your finger and see if a small amount of pressure will put the lens back ito position.
In the end, this is not a new camera, if it is dead a better replacement can be had for as little as 120 $US
Jul 27, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Dec 03, 2008 | Canon PowerShot A510 Digital Camera
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon powershot sd30 digital elph
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
Lens error
Same problem here - the forum posting on the SD 500 seems to be a bit more active (for the same problem).
http://www.fixya.com/support/t102982-e_18_problem
I have been trying to get some images or a service manual for the SD 700, with no luck...
Mar 15, 2008 | Canon PowerShot SD700 IS Digital ELPH /...
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD1000 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
