Kenmore 24032\24036 Top Load Washer Logo
M
Mike cord Posted on Apr 04, 2014
Starts to spin then stops and sounds like it shuts off
athleticsoul
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Apr 04, 2014
athleticsoul
Contributor
Level 1:
New Friend:
Answers
Questions
6
Helped
1028
Points
8
You are probably overloading it. When it stops just open it, take some clothes out and rearrange the clothes in the washer so that they are as evenly spread as possible. Close the lid back. It should cycle on again. If it does not, repeat the same procedure. When the weight/ bulk of the clothes is small enough for the machine to handle it should then complete the cycle/wash.
Maytag Bravos washer starts cycle and fills, but at noise at agitation/spin then starts and fails immediately
i reccomend you check the drive belt if its worn, damaged, or misaligned. motor bearings that are damaged can result to result in grinding noise
Washing machine wont drain or spin. It will agitate, but as soon as it clicks over to spin and drain, it shuts off.
Sounds like the motor is bad, dos it start to spin then stop, then this is the case, but if it never starts spinning then check the door lid switch,
Washer leaks and keeps shutting off when it starts to spin.
 it sounds like your washer is not draining before it starts spinning. the machine should not have visable water in it when it starts to spin. make sure there is no water in the machine and that it is draining properly.
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Alexander
vince
