Question about Honda EU6500iS Inverter Generator
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Posted on May 25, 2014
SOURCE: honda es6500
If the low oil switch fails, you have to jump the switch for the engine to operate. I have a compressor with that problem. Then either you watch the oil level carefully or install a new switch, which, in my case, requires disassembly of the crankcase.
Gary
Posted on Aug 29, 2011
Mar 25, 2018 | Honda EU3000iS Inverter Generator
Feb 13, 2018 | Honda Garden
Feb 11, 2018 | Honda Motorcycles
May 03, 2015 | Honda Motorcycles
Jul 18, 2013 | ATVs
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
Jun 18, 2011 | Garden
Jul 11, 2010 | 2002 Honda CR 250 R
Jun 21, 2009 | 1982 Honda GL 1100 Innerstate Gold Wing
May 15, 2008 | 1997 Honda Civic
1,023 people viewed this question
es6500 generator. Turns over, fire at both plugs (new coil) gas in tank and at carb (no power to bottom of carb) oil light comes on then when cranking goes out (jumped it out as well) traced wire from carb to switch follows all the way back. Jumped out radiator sensor. Pulled flywheel to make key way didn't shear. At a loss no Idea. Have 12volts at both diodes or switches in control panel. When turning over have 3.9-4 volts dc at them. Got me stumped. Thanks
