Samsung LE40R74BDX 40 in. LCD Television Logo
g
gary heiserman Posted on Apr 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sylvania lc320slx tv works great for about 30 min then starts to flicker and goes black if tou wait a min and turn it on again it doue the same thing only stays on for a shorter amount of time
gemagm
Level 3:
Master:
  • Samsung Master 689 Answers
  • Posted on May 09, 2014
gemagm
Samsung Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119874
Points
1147
Possibly the capacitors in the power supply. You can identify the bad ones by their bulging tops. If you have the wherewithal, you can replace them for about $10.00 or less.
5 Related Answers
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 28, 2009
SOURCE: screen goes black but not off hps5033
the start relay in your power supply has burned points and, needs to be replaced; this requires finding the part and, then unsoldering the part and, soldering in the new part. If you feel capable of doing the repair let me know
Anonymous
  • 304 Answers
  • Posted on Jul 17, 2009
SOURCE: samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Anonymous
  • 1637 Answers
  • Posted on Jan 16, 2011
SOURCE: Samsung ps42p4h1x screen flickers and then goes
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
karmtec
  • 7 Answers
  • Posted on Aug 08, 2011
SOURCE: When turning on TV Samsung 52 , 3 years old it
It is really easy to fix yourself if you can use a soldering iron. There are kits available at http://www.karmtec.com and specifically for this TV here.
Anonymous
  • 14553 Answers
  • Posted on Apr 27, 2012
SOURCE: how do I fix this problem
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical bad puffed up caps and if you have questions or need advicelet me know.4_27_2012_11_02_42_pm.jpg
1helpful
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
3helpful
I have a Sylvania LC320SLX that will not turn on. When I hit the power button, the power on light blinks about 15 times then goes back to standby. I disconnected the cable input and unplugged the power...
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
2answers
I have a sylvania LC320SLX tv and cannot program it with a DirecTV RC64 remote. I saw on your fixya.com site that 11864 works with a DirecTV RC65 remote and wondered if you have tried it on the RC64?...
These codes control Sylvania TV with the RC65, & I suspect they work with the RC64: 11864, 10171, 11271, 11314, and 11394.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
3answers
Remote code for att uverse to sylvania lc320slx lcd tv
Try all Funai codes too, starting from the last in the list.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
