Thank you.
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
SOURCE: just did a kitchen remodel, kept the Bosch
Ask a local granite fabrication shop to get you some dishwasher mounting
clips. They look like a perforated disc of metal with a small nut
brazed to one side. They come with a short screw that attaches through
your dishwasher mounting tabs. Place your dishwasher where you want it
relative to the cabinets and pick a hole in the mounting tabs that won't
leave the clip protruding and attach the clip to the chosen hole. Use
masking tape on the top of your dishwasher door, wipe the bottom of the
granite and the top of the clip with acetone, then use a gel-type two
part epoxy from your local hardware store to attach the clip to the
granite. Use enough to make the epoxy push through the perforations in
the clip as this is how the epoxy grips the clip. Push the clip to the
bottom of the granite and close the dishwasher door, using a wood shim
or two between the top of the door and the mounting tab/clip to push the
clip tight to the granite. Pull the shims out once the epoxy has cured
(check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - [email protected] - http://.www.StoneRepairman.com
