Question about Electric Kid Trax Side Kick Scooter Ride On
Ezip 450 Not charging brand new light goes green when charging but no lights when unplugged
Posted by Yosi Taviv on
eagle
    New Friend:
  • 4 Answers
I have noticed some of these models needs the key on to charge. this completes the circuit to battery. I have a different model and that is the case.
-also like the other post would be good to verify that charger and battery are good.
-after that you are looking at issue with little harness/ brain have not found easy way to test this, but can replace unit*
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harness to new harness to fit bike. Works great.
Posted on Apr 02, 2016
Desktopsbyduck-Computers
    Genius:
  • 1,061 Answers
Possible bad charger can u test it ?
Posted on May 03, 2014
3 Related Answers
IQUIT
  • 3940 Answers
SOURCE: old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
Posted on May 03, 2009
SOURCE: my brand new toshiba netbook nb200 shows a red
May be a bad battery or charger.You said new contact toshiba for a replacement.RICHARDM69
Posted on Aug 24, 2009
krbshg
Banjade
  • 430 Answers
SOURCE: wont work on battery power, turns off when unplugged
Have you tried Charging with other charger?
In your case it sounds like your Battery is allmost dead. So I'll suggest you to Visit HP site and download Battery testing Software.
With that software you can how if your battery is ok or not. If the software shows you that you need to replace battery then there is no option rather then listening to the software.
Posted on Aug 02, 2012
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
I have a ezip 450 electric scooter doesn't run.I
Check the brake micro switch and brake coil resistance plus all wires in this area.
Oct 09, 2014 | Health & Beauty
Hi I have a ezip 400 scooter we just bought a new charger and the charger has a green light but the ezip its charged I was thing maybe its a loss wire or something I got the ezip from someone said if
Push the circuit breaker back in first. The scooter will not move if the charger is connected. If the scooter has sat unused for a long time, the charger will NOT recover the batteries. Charge them individually with an automotive charger until the voltage is at least 11 volts each. May take a 12 or more hours. If you can't get 11 volts after that time then the batteries are gone.
Oct 04, 2014 | Health & Beauty
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Ezip
The light came on because the charger brought voltage up to full, but when you hit the throttle, the voltage dropped since the charger cant power the motor. While checking the wiring (which I assume people automatically do), bypass the power switch with a screwdriver or a jumper wire. If it works, replace the switch. Check the battery with a multimeter...you should get > 25.2v full charge, no load. If you get 0v, check the fuse in the battery case. If all of the above check out ok, and it's totally dead, you probably need a controller.
May 28, 2013 | Currie Technologies eZip Mens Trailz...
Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | JUMP START SYSTEM
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Electric Kid Trax Side Kick Scooter  Ride On Logo
331 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
