Question about GE WSXH208A Front Load Washer
Ge front load washer won't spin
I got all sorts of junk out of the front drain plug .tried it again and still won't work.pump is running.could pump still be bad even though it runs?also i'd like to know how to get the front control panel off the machine to maybe check codes and switches . it's a model # WBVH6240HVVW .thanks for any help.
Posted by mrquaid on
  • 2 more comments
  • RandLong Nov 18, 2007
    In the past our machine would sometimes not spin. I solved the problem by recycling the dial. This time we cleaned out the pump area...got over five dollars inchange and a guitar pick out of the red thingy in the pump. Still won't spin. Bummer. I have 5 loads waiting. (:
  • ARRGGH Jan 07, 2008
    Have a GE front load (WSXH208A) washer and the pump seems to be stuck, as it continues to run even after the tub is empty. The tub water level sensor seems OK. Anyone with suggestions? Thanks much.
  • Anonymous Mar 22, 2014
    The error light flashes 10 times indicating *check backsplash control*. I've disconnected and reconnected everything. I did the reset and the light does flash for normal operation but I still can't get it to work. No lights on the front panel light up and no response to any controls. After awhile the light goes back to 10 flash error code. I did drain the tub and found no obstructions. The machine may have been in the final spin mode when it stopped working. I found an unbalanced load in the wash and the machine had moved itself about 6 inches from its original position. I did test the outlet and it is good.
  • Anonymous Apr 01, 2014
    How do you get the front panels off so that you can change the switch?
Anonymous
    Problem Solver:
  • 19 Answers
Replace the drain pump.and 2 remove the control panel u need 2 remove the 3 screws from top cover from the back
Posted on Nov 01, 2007
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My ge wbvh6240fgg front load washer will not spin or pump the water out. I have pulled the plug and waited a minute then pluged it in again. No success. It goes into pause. I can hear a quied moterized...
heatman101
Sep 07, 2010 | GE Energy Star WCVH6260F Front Load Washer
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
Pos ge washer WCSR2080B
Sounds like u might be having trouble with the lid switch.. U need to also check you water pump out.. this model has a electric pump that may be plugged... dont take much to plug this pump up.. have you taken front panel off yet ? Post what ya find
Oct 16, 2007 | GE WDSR2080D Top Load Washer
GE WSXH208A Front Load Washer Logo
1,192 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
