HP Compaq DC7900  PC Desktop Logo
Thapelo Donald Mofokeng Posted on Apr 03, 2014
NO SOUND OUTPUT
SOUND DRIVE DONT WORK
Rajib Azam
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 04, 2014
Rajib Azam
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
238
Points
Reasons can be:
1. you have a corrupt driver.in that case uninstall and reinstall the drivers.
2.the device or the driver is not supported by the OS.
3.check whether the speakers are working properly , hold speakers one by one close to your ear while it is on you should hear a hissing sound confirming that they are alright.
4. change the port of the sound card see if that works
5. and if none of the above works it has to be the sound card itself.
think servicing before buying another sound card.
Why does my pc dont have any sound?
Do you have a working audio card with correct drivers ? Do you have speakers connected to your audio card's sound output ? (Green color inlet)
2answers
Dont know where to plug in my speakers
Do you mean on the motherboard?
Let me know, and I can give you more information.
Thanks
Jason
1helpful
I have a pair of Boston Digital BA735 speakers that wont work on my toshiba gs6000 laptop. I dont know if my soundcard only supports analog output. I dont see an option for digital output in windows 7 or...
These are Digital speakers and not suitable for Toshiba satellite units. Most sound cards in the L series are analogue only. So your own Diagnosis was on the money.
Please rate my help++++Thanks for using FIXYA
2helpful
Connecting to ports?
Generally the input/output jacks on computers are color coded and the green is for speak output. If you still don't get sound, verify you have working sound card drives installed in your OS and that the volume isn't muted.
My NetVista 6578 has no video output even upon booting so I can't even tell what's working? It used to be on a network, now I'm trying to use it as a single user machine. Is there a switch setting to...
Sound like a card or ram chip,
pull out the ram first and see if you get the video to work with no ram instaled,,
if it works but beep many times the ram is bad,
Also try this with all the cards, hard drives and cd/flopy drives,
keep the video card pluged in,
If it dont come on after all this and you keped the video card in when testing. then its a bad video card,,
If the pc is shows no life then its the power supply, motherboard or on/off button
I have no audio on the HD stations with my Hitachi Ultravision television. My Sony flatscreen in another room works fine.
Check if the audio output on A/V pins have a fine sound output on the audio pins, using a headset. if you dont hear a fent sound from the pin sound coming from the pre amp, then take your tv for a replacement of an audio ic output power amplifier.
thanks.
NO SOUND
have you check your audio driver? audio driver drives audio output its nothing to do with video card. reinstall your audio driver to fix it.
Lost sound output
Computer Sound Card Help A sound card or audio board which allows computers to output audio signals through .... CH000208, Missing or lost sound in Windows 95 / 98 / ME / 2K / XP ...
Good Luck, Please dont for get to Vote/Thank You.
No picture or sound
The fact that its making a sound everytime it trys to start up tells me that the horizontal drive/output section is not starting up.. The set needs to see a hoirzontal drive signal in the power supply to start up or the power supply is starting up and being overloaded by a short circuit somewhere in the set. First thing to check IF and only if you have tv trouble shooting experience would be the horizontal output circuit and the vertical drive circuit. I once even had a rear channel audio output IC cause the very same sysmtom. Please seek the assistance of a pro if you dont have any tv experience. Good Luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
