Question about SanDisk Sansa e250 MP3 Player
Sansa e250 every time i try to hook up my sansa e250 it said hardware can t be found..i need help
Posted by lostbaca on
  • Anonymous Nov 02, 2007
    How do i change the mode, and when i put it on the usb something pops up saying "found new hardware" and i click next and it installs something and then says there has been an error
Timothy D
  • 626 Answers
Try changing the MODE on the device thru Settings>Mode or USB Mode.
Then try connecting to the PC again.
If that doesnt work, add to the question and ill try something else.
Best of Luck.
Posted on Oct 31, 2007
I need help
The device is supposed to refresh each time in case you put in a new memory card or added additional files. That's not the problem - this is: There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
May 16, 2009 | SanDisk Sansa e250 MP3 Player
My sansa mp3 won't work on my computer
the problem is you have not installed the drivers yet all mp3 player have to have some sort of drivers in order to run correctly on your pc if you have you sansa e250 disk still around id recomend reinstalling the information stored on that disk and go from there hopefully this helps you
Feb 04, 2009 | SanDisk Sansa e250 MP3 Player
My PC doesn't recognize MP3 player "sansa e250"
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............
Just make sure it is not Locked or On Hold and then try to turn it on.........
Good Luck.......
Take Care
And now it should recognise it
Jan 22, 2009 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250..thnkx.!!
I think maybe it isnt connected to the computer corectly because it should go to the connected screen. try hooking it into the main USB ports.
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps connecting and disconnecting from the computer. every time i plug it into the computer, it keeps saying that it's connected and disconnected to the computer. this switches repeatidly...
If it is flashing constantly, go into Start --> Control Panel --> Printers/Other Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Pleaze help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 14, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
I am running a Sansa and an Ipod simultaneosuly with no conflict, so the problem is definitely with the Sansa.
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
Help!
Try this;
Best of Luck.
Nov 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
