Printer has been stored not used for a few months and when I went to use it yesterday it powered up fine and scanner worked fine to until I went to print something... the printer did its normal routeen of clunking and going went to print then heard what sounded like a fuse blowing it the only way I can describe the faint noise... then the printer shut down and now wont turn on. when power button is pressed all I get is a brief flash of the green light and nothing. I have looked at epsons website and tried the holdling the power button for 5 seconds but this doesn't seem to do any thing can any one please help me thanks
SOURCE: Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
SOURCE: Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
SOURCE: epson stylus d92 printer
I think that this "error"is due to an internal copy counter.
I have a Epson Stylus D68PE, and had the same problem.
I performed a research for a file to reset the internal counter, and I found a file "C67C68D68" that is an "EPSON ADJUSTEMENT PROGRAM", with different softwares for each type of printer.
after launch the program, and reset the counter, the printe work OK.
This counter is as similar as the counter of the laser copiers.
As you reset the chip on ink tank, after a specific numbers of print, you must reset the internal counter. By yourself, of by MAINTENANCE (very expensive) Good luck.
SOURCE: r2400 foreign object error
return printer back you not gonna solve this problem this is head malfunction
SOURCE: Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Renai,
All you need to do is to click on this website: http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=1000000
Then you go through the click on your computer which should be pictured. You will then be instructed to download the driver for your computer. You should also find application downloads and instructions on using your printer.
The same thing happened to me a few months ago. I have a Dell A940 all-in-one and had cracked the original installation cd. I went to Dell's Official Website and found what I needed.
I do hope this helps you out.
Cheryl Cummins
